94-97 coupe/sedan rear swaybar fit the wagon?
Hey guys,
I'm looking to build my 1997 LX wagon into mainly a daily driver, but a track car as well. I have an E36 M3 and a S13 240SX but I dislike going to the track and seeing them all over the place. Love standing out. I miss the feeling I had when I tracked my 92 Prelude.
Anyway, does anyone know if the coupe/sedan anti-swaybars fit the wagon, too?
Thanks!
Thanks!
From what I think I am seeing no DX/LX came with rear sway bar from the factory, only the EX. Looking at the EX part on HondaPartsNow it states that the bar fits all 2/4/5 door.
HondaPartsNow
From a little bit of quick reading I'm seeing that you should check and see if you have holes pre-drilled for it, if not you will need to drill them if you are planning on installing a stock EX bar. Or you might choose to switch out the whole rear to the EX.
Here is some reading for you.
AccordWagonClub
HondaPartsNow
AccordWagonClub
It should fit without a problem if I remember correctly.
What sway bar are you going with? Progress bars require you to drill and thread holes. However, because I have an LX sedan that does not come with a rear sway bar, I opted for the ST Suspension rear sway bar. No drilling required and it was an easy install.
hydengr
Honda Civic (2001 - 2005)
11
Feb 27, 2009 03:43 PM
luispizarro25
Aug 8, 2008 05:37 AM
M-EJ1
22
Jul 26, 2002 06:04 AM
