Revlimter removal
Old Nov 4, 2015 | 07:52 PM
TheRookie74's Avatar
Default Revlimter removal
p28 ecu, can it be removed, if so what can I take out of it to remove the revlimter. this car is simply a dirt oval car it is unneeded. thanks
Old Nov 5, 2015 | 07:02 AM
civic-steve-94's Avatar
Default Re: Revlimter removal
Find a local tuner to chip your ecu and he can program what you want and maybe optimize your fuel map
Old Nov 5, 2015 | 10:07 AM
Nottheonion's Avatar
Take out the flux capacitor
Old Nov 5, 2015 | 08:24 PM
I know where your coming from though I had an 86 prelude si that I ran on a 1/4 mile asphalt oval and was on the limiter for the last 50-60ft of the straights. Went through 3 head gaskets due to overheating and predet before the head bolt(which Honda no longer makes) stretched to far to use but won some races before it died.
Old Nov 6, 2015 | 09:45 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Needs to be chipped, BUT you need to make sure you have parts to support your higher or non-existing rev limit. Otherwise you will have valve float and eventual complete engine failure (dropped / kissed valve = whole rotating assembly destroyed as well as head).
Old Nov 9, 2015 | 07:31 PM
i have a built motor, crower rods-wiseco pistons 12:1
Old Nov 10, 2015 | 03:40 AM
DO IT ON ALL FOURS
That has nothing to do with the rev limitations of the valve train. However, you did eliminate the problem of the weak rod bolts and connecting rods.
upon1cbr
Aug 6, 2009 07:59 AM
USDMMARK
11
Nov 6, 2003 06:01 PM
TypeR JunioR
Aug 1, 2003 10:08 AM
91HATCH
28
Sep 20, 2002 08:44 PM
JDMchris
Jun 1, 2002 02:45 PM
