Change in compression. Ecuador compensate?
Old Nov 3, 2015 | 07:29 AM
Chops13's Avatar
Default Change in compression. Ecuador compensate?
Bought a gsr and the crank is roached. It's easier for me to find an ls rotating assembly than a gsr. If I did ls crank and rods with p30 pistons it would be me around 11.5:1 compression. Would an obd2 Ecu compensate for that much of a jump or would I need a retune. Really not looking forward to converting to obd1 and getting a tune. It is what it is I guess. Otherwise I'll just play the waiting game on a gsr crank and rods. Or is there some other oem style piston I could run without having to notch anything and lower the compression closed to stock? Can a mod change thread title. Remove Ecuador and replace with ecu.
Old Nov 3, 2015 | 09:06 AM
Chops13's Avatar
Default Re: Change in compression. Ecuador compensate?
Found my answer. Needs tuned.
TravisBiggie
Feb 23, 2015 01:11 PM
teggrl
Feb 21, 2009 07:38 PM
boostd ls
Dec 7, 2005 08:29 AM
NightmareApex
Nov 29, 2004 07:15 PM
EGkid
26
Oct 25, 2004 10:08 AM
