Honda CR-V & Element 2WD & 4WD Element & CR-V
Help me give my new ride a birthday :) [1998 5spd]
Old Nov 2, 2015 | 11:35 PM
ButtersNZ's Avatar
Default Help me give my new ride a birthday :) [1998 5spd]
Hey all, I just picked up a 1998 CR-V in manual with 250km on it.
The last owner did pretty minimal maintenance saying he topped up the oil as needed over the last two years..
So first things first, tomorrow it's getting some love in the way of a new stereo, and a cut polish and some painted trim.. and much needed maintenance.
I would like to know what oil I should buy for it.
What spark plugs these engines like (B20B)
What else should I do? Fuel filter? Air filter looked clean.. clean/check IACV, dizzy cap and rotor?
Forgetting anything?
Cheers all!
Old Nov 3, 2015 | 05:15 AM
JoshTheJerk's Avatar
Default Re: Help me give my new ride a birthday :) [1998 5spd]
http://owners.honda.com/service-maintenance/minder?year=1998&model=CR-V#mid^RD174WPBW
This will give you a basic rundown of things that should have been done over the years.
Old Nov 3, 2015 | 10:08 AM
ButtersNZ's Avatar
Thanks that was very helpful
Old Nov 5, 2015 | 12:49 PM
BigBerz's Avatar
How does the head sound? If you don't know when the last valve adjustment was done I would advise doing one as a precautionary measure.
Berz out.
Old Nov 5, 2015 | 09:02 PM
Honda4Life.'s Avatar
Engine oil and filter. Cap, rotor, wires, plugs, PCV and fuel filter. Change the coolant, trans fluid and rear diff fluid if AWD.
Id look into doing a valve adjustment and check the condition of the timing belt. Id personally get ready to do that along with the water pump and other accessory belts. At that time it wouldnt be a bad idea to do cam and front crank seals as well. Check for oil around the base of the distributor. May need to replace the seal there too.
Old Nov 5, 2015 | 10:07 PM
ButtersNZ's Avatar
Oosh $$$ haha. I'm keen to check out the Exhaust valve gaps. Timing belt and water pump will have to wait, got another 50k due on the belt. Thanks for the advice
Old Nov 8, 2015 | 04:02 AM
Wannabe JDM's Avatar
That's going g on the assumption that the tbelt has ever been changed. Could be a ticking time bomb.
Old Nov 8, 2015 | 04:56 PM
ButtersNZ's Avatar
It was done 50k ago
Old Nov 15, 2015 | 03:31 PM
ButtersNZ's Avatar
OK!
I have a problem.
After refueling at BP yesterday the V started bogging down/misfiring under acceleration. It was brief at first but by the time I got home it was constant unless I very gently opened the throttle. It feels like spark or bad fuel or fuel pump. I gave the petrol station a call and they say the fuel has tested OK.
I drained out the entire tank anyway, and put Shell 95 in there, swapped plugs to another set, cleaned all the points in the dizzy, found and fixed a manifold air leak, put in a new fuel filter and set the valve clearance for exhaust and intake.. Interestingly the valve clearance was too great on most of them, so I really had to tighten things up instead. After all this it was running great into town and for the first time power really kicked in at 5k+rpm, like a vvti system or something. Then it started bogging down again a little, but not to the point of yesterday.
Pretty unsure what the next step is. I think I've done all the cheaper fix options. Still think it might be a fuel issue..
Any thoughts?
Old Nov 17, 2015 | 09:38 AM
BigBerz's Avatar
Can you do a compression/leakdown test?
Berz out.
KevinEJ6__17
Jul 6, 2014 01:55 AM
vietkangta
Jul 28, 2007 12:43 AM
hnp5
Jan 18, 2006 02:39 PM
goowakjai
Jul 15, 2005 10:29 PM
Hybrid Boy
Sep 1, 2002 03:16 PM
