Del sol performance
Ok so i just bought a del sol, my first car a month ago, i wasnt much into cars but once i started driving i started feeling it and worked a bit on it. Its a 94 vtec from japan, i honestly dont know much about cars as im getting sucked into them slowly, id really apreciate if you guys would help on how to make it faster, add more horse power, just make it better sportswise, ive seen videos and how people put turbos on it, what else can i do?
Because you have the VTEC model you have the performance B16 head. If your engine is high mileage and you were thinking of rebuilding it an option would be to put that head on a Integra B18 block or a CRV B20 block. This would be called a LS VTEC conversion. Research this in the FAQ section.
I also have a 94 del sol vtec with a Integra Type R head on a B18 block. Kind of the next step up from what the B16 would be.
VTEC. Not vtech. It's variable valve timing, not a kid's toy, and not a phone. Just to be sure, though, you have a Del Sol VTEC, and not a Del Sol SI (which also has a VTEC-equipped motor, but a different motor)? Exactly what motor is in the car right now?
That being said, go read the FAQ sticky. They exist for a reason. You aren't doing anything new, and we aren't here to spoon feed.
allmotorEG-SI
22
Dec 31, 2008 09:17 AM
