fuel pump doesnt hum
Old Nov 2, 2015 | 10:42 AM
Jdm Harrison's Avatar
Default fuel pump doesnt hum
I have a 2000 honda civicand the other day i was driving and heard a clicking by my ecu area then my car turned off ever since my car wont turn back on and my fuel pump doesnt hum need help before i start doing anything to it
Old Nov 2, 2015 | 10:48 AM
Former User's Avatar
Default Re: fuel pump doesnt hum
"helpp" is not an acceptable thread title in tech forums. Read the forum Rules sticky.
...then try cleaning the G101 ground on the thermostat housing.
Old Nov 2, 2015 | 11:03 AM
Sorry man i just needed help asap and didnt read them and where is that located
Old Nov 2, 2015 | 11:05 AM
tony_2018's Avatar
Fish Twig
top of the thread, stickied, and greyed out.
Check to see if you're getting power to the pump and work your way backwards to the main relay.
Old Nov 2, 2015 | 11:57 AM
Thanks guys ill be using this alot more for help but the correct way now i know haha i got it to start but by the manifould its making a hissing sound like maybe a air leak know what that could be
Old Nov 2, 2015 | 12:44 PM
delsolintegra's Avatar
Vacuum line leak. Could be line to the fuel pressure regulator or the PCV valve.
Probably some others too.
Old Nov 2, 2015 | 12:53 PM
Okay nd i tried to drive my car aftervit got started and my ecu fuse keeps blowing and car wont go back on without a jump i have a jdm d15b
Old Nov 2, 2015 | 01:07 PM
Check the G101 ground on the thermostat housing. Make sure the wires are unbroken and the connection is clean. This is the ground point for the ECU.
Old Nov 3, 2015 | 07:21 AM
That can cause the fuse to blow?
Old Nov 3, 2015 | 07:31 AM
Which one? There are three.
Old Nov 3, 2015 | 07:49 AM
The one next to the back uo radio fuse on the left of it it says like " FI E/M "
bimmeracer
Nov 3, 2008 08:46 PM
iNDyCRX
Apr 24, 2008 12:54 PM
trooper0641
Feb 1, 2006 09:40 AM
Vtecnsi00
Nov 30, 2004 09:08 PM
CRXMATT
Mar 20, 2003 06:01 PM
