87 Accord LXi Main Relay Harness Test
I have a first edition 87 Accord factory manual and under Harness Test on page 12-69, number 9 it says "Connect a jumper wire between the Black/Yellow wire (5) and the Yellow wire (7).
However, the associated diagram however shows the jumper wire between (1) and (7).
Which is correct to use the harness to test if the fuel pump will run.
The three prior harness tests all tested correctly.
lonely_driver4
Jan 31, 2019 07:46 AM
