cel 41 help
Old Nov 1, 2015 | 10:13 AM
swizz977's Avatar
Default cel 41 help
1992 si d16z6
i just got my car back from being stolen
i had to replace my ecu i got one from a 95 ex manual
but now everytime i start the car im getting a cel which i never had gotten before
i changed out the sensor and still got the same thing
when i take out the back up fuse or unplug the ecu and start the car the cel comes on within like 5 seconds
isnt that way too fast to come on for an o2 sensor? could it be a fuse im not sure which fuse it could be
Old Nov 1, 2015 | 11:30 AM
djedd's Avatar
Default Re: cel 41 help
Hi there.Did you replace the sensor yourself or did you take it to a shop.You say its error 41 the o2 sensor heater right.On some Hondas there is 2 of those sensor there is 1 on top and 1 at the bottom of the heat shield on the manifold.Do your car have 1 or 2 of those sensors?
Old Nov 1, 2015 | 11:47 AM
djedd's Avatar
Also want to ask when you drive the car does it run smooth or does it stall and stutter?
Old Nov 1, 2015 | 11:53 AM
NotARaCist's Avatar
I never narc'd on nobody!
92-95 Civics will only have 1 O2 sensor, djedd.
OP, do you have a voltmeter? Sounds like it's time to test wires for continuity, see if any of them have been damaged by the thieves.
Old Nov 1, 2015 | 11:56 AM
Former User's Avatar
Originally Posted by swizz977
1992 si d16z6
You have the service manual, right?
Old Nov 1, 2015 | 12:56 PM
swizz977's Avatar
yes i just never had an issue with my other computer unless my other ecu was bad idk and i tried 2 different ecus and 2 different o2 sensors and the code always comes on within 5 seconds
usually it would take a few mins to throw a o2 code i thought
i guess ill test the wires but what fuses should i check?
i wish it had an obd2 port to see whats going on
Old Nov 1, 2015 | 01:29 PM
delsolintegra's Avatar
I had that problem with my 93 del sol si with D16z6. After I replaced the O2 sensor I still had the light.
The problem turned out to be a hairline crack in the exhaust manifold in the runner just behind the O2 sensor. Even with the heat shield off you couldn't see the crack. The crack caused the O2 sensor to read a lean condition.
I replaced the exhaust manifold with a ebay header.
I heard a cracked exhaust manifold in that particular area is common.
Old Nov 1, 2015 | 02:29 PM
swizz977's Avatar
could be but i have a99-00 tubular y8 manifold on there
Old Nov 1, 2015 | 02:52 PM
NotARaCist's Avatar
Still worth checking for leaks, while you're checking the wires for breaks.
Old Nov 2, 2015 | 09:44 AM
swizz977's Avatar
ok with the key on one of the wires is getting 12 volts
i also put a test light on the ground and posative and it lights up so everything is good
somthings not right
Old Nov 2, 2015 | 01:46 PM
swizz977's Avatar
just got a brand new denso sensor and the same thing happend cel 41 came on within 3 seconds
Old Nov 2, 2015 | 01:57 PM
Why are you ignoring the troubleshooting well described in the service manual, again?
Old Nov 2, 2015 | 02:06 PM
swizz977's Avatar
ok when i change the ecu to a different one my friend gave me from an auto the only code is 19 which is the auto trans lookup somthing and no code 42 just 19 so could it be the ecu is the issue??
Old Nov 2, 2015 | 02:07 PM
swizz977's Avatar
ron i tested everything what are u talking about?
Old Nov 2, 2015 | 03:21 PM
I would guess something is wrong with the original ECU because like you said the cel is coming on too fast. I think a good ECU runs open loop until the engine reaches operating temp than it would show a cel for a bad O2 sensor if necessary. If you pull the ECU fuse to clear the memory and then restart the engine does the light still come on real fast? These ECU's capacitors can fail in odd ways and cause odd circumstances.
Old Nov 2, 2015 | 03:27 PM
NotARaCist's Avatar
There are four wires for you to test. You only tested 2.
Old Nov 2, 2015 | 05:20 PM
swizz977's Avatar
yea it comes on very fast when i reset the ecu
theres a way to test it but it says i need a test harness
i had to buy this ecu off craigslist because the thieves took my origional one
Old Nov 2, 2015 | 05:44 PM
NotARaCist's Avatar
You don't need a test harness. Just backprobe with a voltmeter.
Old Nov 2, 2015 | 10:08 PM
djedd's Avatar
Cel code 19 = Automatic transmission lockup control valve.
Old Nov 3, 2015 | 09:38 AM
swizz977's Avatar
how would i backprobe it all it says on the service manual is to use a test harness
Old Nov 3, 2015 | 09:59 AM
tony_2018's Avatar
Fish Twig
stick one probe in a23 and stick the other probe into a6, whats the reading
Old Nov 3, 2015 | 10:33 AM
swizz977's Avatar
with everything plugged in the ecu and they key on
also did u mean a 26?
Old Nov 3, 2015 | 02:29 PM
swizz977's Avatar
sorry i should of put this page up too
Old Nov 3, 2015 | 05:00 PM
swizz977's Avatar
it says that if i unplug the a connector and if im getting power to the o2 harness then i have a short? is that true?
Old Nov 5, 2015 | 04:35 AM
swizz977's Avatar
ok so i bought another p28 yesterday plugged it in and no code so i guess it was the ecu
the one on the left is the new one with no code and the one on the right is the one that throws the cel 41
now for some reason the sticker was peeled off the side of the new one on the left but if u open it it says a00 so thats good but im just wondering if any of these look tampered with because on the new one on the left the casings are different
