question on y8 intake swap
last owner did a y8 intake swap on my 97 coupe. he left the y8 tb on so im getting a rough idle ect.. i picked up a y7 tb & IACV im just not sure what wires i need to splice into?? any 1 got a wire diagram?? i googled but couldnt find what i needed
It could have been the fuel injectors. If the previous owner used 240cc fuel injectors that came with the y8 IM than you are getting too much fuel.
May not of been the TB at all.
You shouldn't need to splice anything. The pigtail should be there for you to directly plug in the IACV, unless the PO already did the proper IACV conversion.
Before you go diving down the rabbit hole of replacing random ****, let's do some proper diagnostics. Is your CEL on? Does it work?
still running the y7 injectors an rail... he was running a vtec ecu so i bought a stock y7 ecu an im getting a code for the iacv, the y8 iacv is on the intake the y7 iacv is on the tb.. was told i need to put the y7 throttle body on the y8 intake
Gotcha, so you searched, but didn't find the stickied thread, right in this very section...?
Suspetice.
https://honda-tech.com/honda-civic-d...-vtec-2987229/
Suspetice.
IIRC, Doesn't the EX automatic T/B have the 3 wire IACV on the bottom ??? Why couldn't you use this with your Y7 ECU and extend the wiring if necessary... and if the Y8 Intake manifold was originally for a manual, simply leave the two wire IACV bolted to the back of the manifold and unplugged.
Do you have the 3 wire automatic IACV, or the 2 wire manual IACV currently installed? Given all of the talk about the PO converting to 2 wire, we're all operating on the assumption that you have a 2 wire IACV. No, you can't just clip the plug off. I've already given you a direct link to what you need to do to convert to 3 wire. Do it. Simple as that.
the 2 wire iacv might be open so that is why i suggest the air port on the intake manifold be plugged up or else there would be a vac leak, idle will be hard to adjust. I've done this on my current setup before it was converted to 5spd. It had the 2 wire iacv and I had to use a 3 wire auto iacv. Had idling issues so I had to plug up the hole leading to the 2 wire iacv. I later bought a block off plate.
Red_ED8
Apr 30, 2008 05:22 AM
kkim
12
Jul 5, 2005 05:41 PM
1.8Tities
17
Mar 11, 2003 09:38 PM
