Transmission & Drivetrain Gearboxes, Differentials, Clutches
Carbon synchros normal? (pics)
Old Oct 29, 2015 | 11:07 AM
norcalB18's Avatar
Default Carbon synchros normal? (pics)
This is a picture of my carbon synchro.. The synchro slides down enough to where it touches the gear.. is this normal?
Here is a picture of my stock synchro.. notice the space in between the synchro and the gear..
Also since the synchro slides down more than the stock synchro... The synchro itself has more play in between gears allowing it to move around alot..
Is it normal for carbon synchros to do this? or Do i need to order another one from synchrotech?
Old Oct 29, 2015 | 11:17 AM
norcalB18's Avatar
Default Re: Carbon synchros normal? (pics)
Got a very quick response from David @ synchro tech saying the synchro is actually worn out. There should me a 1 mm space in between synchro and the gear cone it sits on.
This was causing me to miss shift at high RPM.
Old Oct 29, 2015 | 09:23 PM
slowcivic2k's Avatar
The blocking ring (brass part) should not mate flush with the gear surface. If it does, no friction will be transmitted to slow the gear down when the shift fork moves the collar over both parts, resulting in a clash between the gear and the blocking ring (grind).
The fit you have pictured is a completely unusable blocking ring. The last one appears near new. There is a gap specification for these two parts, and this gap might change slightly with aftermarket parts. Reference a service manual for the wear limits if you are not certain. 1mm is not an unreasonable new measurement.
Old Nov 1, 2015 | 09:33 AM
F22Master's Avatar
From the 00 Integra FSM
Standard: 0.85-1.10mm (0.033-0.043")
Service limit: 0.4mm (0.02")
Old Nov 1, 2015 | 04:00 PM
1HGEJ2's Avatar
Can u make some pics of carbon?
Old Dec 4, 2015 | 04:53 PM
norcalB18's Avatar
Old thread.. i've already replaced the syncrho but here is a picture of the worn out inner carbon lining that caused the synchro to touch the gears.
Old Dec 4, 2015 | 06:39 PM
F22Master's Avatar
How much use do these synchros have since new?
gringotegra
Apr 2, 2013 12:52 PM
CX-Adam
Feb 17, 2013 03:57 PM
snwsk8r8
Jun 16, 2011 02:17 PM
MOVE OVER
Jul 19, 2007 05:19 AM
JDM_EK4_Coupe
11
Apr 29, 2007 05:50 PM
