Carbon Coated Gear Syncros
Darth ModerVader
Re: Carbon Coated Gear Syncros (JDM_EK4_Coupe)
According to GearSpeed:
"Our synchros have a carbon coating versus your stock metal teeth. This allows for quicker shifting at high RPM's and reduces high RPM grinding that is common in B series transmissions. The Carbon coating acts as a braking material and stops the gear faster during shifts versus your standard synchro ring."
Re: Carbon Coated Gear Syncros (Padawan)
is there any contact info for gearspeed because im in the process of rebuilding the tranny for some boost action
Darth ModerVader
Re: (mike93eh2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike93eh2 »</TD></TR><TR><TD CLASS="quote">i have brand new gearspeed carbon coated syncros in my brand new tranny and they grind every gear at high rpms.. very pissed off.</TD></TR></TABLE>
Assuming they were properly installed and you're using the proper transmission fluid, have you tried contacting the company about the problem?
Re: (mike93eh2)
get a new clutch or stop trying to shift like you're trying to set a record and that should fix your problem.
Re: (SoCal EJ1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan »</TD></TR><TR><TD CLASS="quote">
Assuming they were properly installed and you're using the proper transmission fluid, have you tried contacting the company about the problem? </TD></TR></TABLE>
tried honda mtf and gm syncromesh.. was thinking about also trying some redline mtl.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SoCal EJ1 »</TD></TR><TR><TD CLASS="quote">
get a new clutch or stop trying to shift like you're trying to set a record and that should fix your problem.</TD></TR></TABLE>
there is absoultely nothing wrong with my clutch. im using a action 2ms. 6 puck sprung.. also have used a tilton flow control valve.
and you can also STFU, you have no idea. im the SLOWEST shifter in the world of shifting, because i dont want to break ****. i sacrafice all boost between shifts just so i dont break anything. besides it doesnt matter how slow i shift. even if i waited like 5 seconds between shifting it still ******* grinds.
Re: (mike93eh2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike93eh2 »</TD></TR><TR><TD CLASS="quote">i sacrafice all boost between shifts just so i dont break anything. besides it doesnt matter how slow i shift. even if i waited like 5 seconds between shifting it still ******* grinds. </TD></TR></TABLE>
damn dude that sucks, i got carbon coated synchros from gear speed in my and i don't have a problem....did you try contacting them? if so what'd they say you figure $275 for synchros they'd warranty them or something....Jasper sent my friend 3 bad engines in a row for his 3000gt and after the 3rd one they paid him labor for having to redo it again.
Re: (1jdmferio)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1jdmferio »</TD></TR><TR><TD CLASS="quote">
damn dude that sucks, i got carbon coated synchros from gear speed in my and i don't have a problem....did you try contacting them? if so what'd they say you figure $275 for synchros they'd warranty them or something....Jasper sent my friend 3 bad engines in a row for his 3000gt and after the 3rd one they paid him labor for having to redo it again.</TD></TR></TABLE>
well i tried pming them.. since its sunday but will also call them.. but i already know what they will say.. they will try and blame it on me, my setup, or incorrect installation..
Ntense90crxsi
10-25-2005 11:24 PM
