Help Please! EK Exhaust Pipe Question
The other day I was driving into work and randomly heard what I thought was an exhaust leak. The next day when I was able to jack the car up I found that this pipe was actually broken. It is the pipe that connects the header to the rest of the exhaust. Obviously it needs to be replaced, what I'm asking is how would I call this specific pipe out to find and purchase it. Thanks!
Once again, any help is appreciated. Thanks.
Looks shitty...if you want a cheap and quick fix, go to a parts store and get a 2" stainless steel sleeve. Works quite well.
Otherwise, pick up another oem header, donut and some hardware.
******* hell. This is why car information is required.
Part #8. 18210-S01-A21 is the part number. Unless you have an EX, in which case it's part #9 in that diagram. I see no reason why the pipe pictured couldn't be the original A pipe.
I'm just saying that because I know exactly what the original one looked like and that's not it. That looks like something a muffler shop bent up and welded up to the original bracket (which has since also failed). It's also missing the spring bolts and the b-pipe appears to be aftermarket too, but I could be mistaken on that.
Hill4589
Aug 27, 2008 02:44 AM
whitelightnin
Dec 25, 2006 02:31 PM
