Hasport EKLH question.
I've been swapping my mounts on my EK piece by piece, (long story short broke my subframe and old mount and had to order one adapt so I just ordered the rear for starters) I've got the rear and trans mount installed and everything is good. Currently I'm running avid mounts that are a lot thinner than the Hasports. The motor is a b18c in a 98 civic, I ordered the Si bracket for the driver side when I did the swap so I'm 2 bolt ready, but I didn't get the stud and nuts I got bolts. Now my question is should I use bolts for the mount, or should I stud the mount and use nuts? On the integras I'm not sure if they include the bolts or not but I was thinking it may be easier to stud it but input would be appreciated. TIA!
webbs2jzgte
Jan 12, 2010 06:04 PM
