Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
intermittent vibration in the front end
Old Oct 27, 2015 | 08:58 AM
danlkb1's Avatar
Icon5 intermittent vibration in the front end
On my 2007 Honda Accord V6 (EX-L) ... I get an intermittent vibration ....Very intermittent.. Can happen at any speed. Usually on slight inclines with slight acceleration. Lasts for say 5-10 seconds then stops. It drives fine at highway speeds/slow speeds...
it started after it was "repaired" (and I use that term loosely) 2 years ago after I was rear-ended. When I take it to the shop, it drives perfectly... (which I've done 3 times so far)... it's not a huge issue, but it does concern me.. I've got 74,800 miles on it and it runs fine otherwise, but the hesitation (forward/back - not side to side) when I slightly accelerate usually going up small grades. Sometimes it seems to happen in neutral also, but it's hard to tell. ... has anyone encountered this and if so.. how did you fix??
Thanks in Advance, Dan
FYI -- When I got it repaired after the accident, the back end squeaked like an old mattress.... I took it to Honda and they found that issue (some of the bolts were not torqued down enough)... I'm thinking the repair also left some other bolts not tightened down to specs as it seems something is loose... but my mechanic can't find anything else... and of course when my mechanic has driven it... it hasn't happened... the accident was 20K miles ago...
Insolent
Sep 23, 2009 02:59 PM
foxjaeger
Mar 12, 2009 09:31 AM
Enathe
May 8, 2006 07:30 PM
DSpaul
Jul 3, 2004 02:57 PM
firehawk456
Aug 6, 2003 05:45 PM
