obd2 integra automatic whats need to tune.
i havent found anything in my weeks of searching so figured id post for anyone trying to do so. first you need to order a obd1 tcm from a 94-95 auto intrga and a obd2a to obd1 jumper a socket / chip kit or a already chipped ecu. remove the drive lower kick cover swap tcms and pull passnger kick panel remove ecu and install jumper and obd1 manuel ecu and now your able to tune your set up. i did this in a 96 ls auto integra with a 350lbs driver so at the track the car weights 3250 with a b20b with ycp pistons and crowler 403 cams and did 15.3 flat passes all day maxing out the factory injectors will be going back and retunning this weekend oone 285cc injectors so it wont hit fuel cut in 3rd gear.
