eg gsr swap dies while driving.
Hey guys i need some help with this annoying issue that i am having. My car would start up great drive perfect. It would randomly die. It takes about 5 min to get it back running. Its been 1 month since this has been happening and im scared to drive it. Been stuck in traffic. I've done some test. It has spark and fuel. New dizzy. New spark plugs. Wires. Etc. The other day i had the car at idle waiting for it to die. It dies sometimes on idle. When it finally did. I try cranking it still wont start. So i decided to mess around and unplug some wires and re plug them. I unplugged the iacv and repluged it. Went back to start it and it work! So i got a new iacv. Drove it the next day and it dies in the middle of the road. Poped my hood and unplug and replug the iacv started right up. So i just made a switch for the iacv routing it to the cabin if it happens again i can just keep flipping the switch. Help. Lol thanks
Unplugging the iacv is just a coincidence unless maybe its getting stuck open.
Maybe unbolt the iacv and check the inside to see if its stuck open
When it dies and doesnt start you need to check for
Air
Fuel
Spark
Compression
Timing
You might be moving the wire harness as your messing with the iacv and its moving another wire making an intermittent connection
Air
Fuel
Spark
Compression
Timing
Air
Fuel
Spark
Compression
Timing
Air
Fuel
Spark
Compression
Timing
Originally Posted by gsr28
ive done compression, leakdown, spark, timing. im thinking a glitch in the s300...... drove it yesterday and did the same thing...... this time it had a hard time starting even when I keep flipping the switch.
Did a good tuner street tune it or you yourself?
Open loop or closed loop?
Full tune or only wot
What are the comp numbers on all four?
Compression is around 190-200 between there. Im not sure about the tuning.. i know him through friends but hes good. And he is. And i dono what open or close loop is. I dono nothing about tuning. Thinking of selling it. Kinda sad when u work at the dealership and fix other peoples cars. But u cant even fix urs. Lol
joe_accord23
Aug 21, 2010 10:45 AM
JDM-EJ698
14
Mar 23, 2008 06:45 PM
sohcVTEK
Jun 18, 2006 08:44 PM
