93 civic ex - Headlight WIRING NEED HELP TODAY! :( PLEASE!
Hey guys, another topic to start.
I started taking apart my wires for my headlights because my low beam wasn't working.
I changed the h4 female plug that the headlight would plug into, but it got a little messy with the wires.
I changed my headlights to the h1 blacked out 1 piece headlights and i have wires running everywhere so i decided to re wire.
I have a DTR Relay where i have a white wire, and an orange wire.
I also have the h4 female plug going to the headlights, but one the opposite side its not connected to anything.
Where do i put these wires, can anyone draw a quick diagram or tell me the colors where they should all be hooked up to.
If it helps im using the haymes DTR from canadian tire.
Thank you very much!
I'm sorry, we can't help you with wiring for Hummers.
(Hint: Read and follow the rules sticky. You've been around long enough to know better.)
Hey guys, i just rewired my headlights and im having an issue.
I have a DTR Relay hooked up to my lights and i wired it as it should be. Highbeams to the Orange wire, and low beams to the white wire.
Like that high beams aren't working, and one low beam is dull (drivers side).
Drivers side high beam hooked up to the white wire, now its bright, and that side works as high beams, but the other side still doesn't have a high beams.
Can someone please explain on how to make this work?
Tell me exactly which wires to hook up and how.
I have the hamsar DTR from canadian tire, its driving me crazy.
I had a bad female h4 plug that i just replaced, and i had to rewire that.
Maybe i wired that improperly?
Which wires should the h4 female plug be going to.
Please with pictures if possible explain.
vtec_head
11
May 12, 2006 05:51 PM
monalisa overdrive
Oct 24, 2004 01:29 PM
