90mm throttle body
Old Oct 25, 2015 | 04:18 AM
94boostedhatch's Avatar
Default 90mm throttle body
What is best 90mm throttle body to go with for b series I have skunk 2 ultra manifold
Old Oct 25, 2015 | 04:28 AM
Default Re: 90mm throttle body
I have skunk 2 90mm but have heard they like to stick?
Old Oct 25, 2015 | 06:13 AM
PSI GUY's Avatar
Ours stuck a bit when it was new but doesn't now. The set screw coming out on the track was another issue all together though.
Old Oct 25, 2015 | 07:21 AM
So the set screw should be loctited an ur saying throttle body needs to break in?
Old Oct 25, 2015 | 04:21 PM
PSI GUY's Avatar
Pretty much.
Old Oct 25, 2015 | 06:21 PM
SonicRacing1's Avatar
Accufab is what i got
Old Oct 26, 2015 | 06:30 AM
hondaracing84's Avatar
Im using the skunk2 90mm. Mine didn't stick at all. I did however adjust the throttle stop to have it cracked open a bit to get my idle right, so maybe that's why. But otherwise, Im very happy. It uses the stock TPS, no adapters or aftermarket TPS needed. So it'll save a little on cost.
Old Oct 26, 2015 | 02:50 PM
redGSRguy's Avatar
I have the 90mm skunk2. Mine sticks even after I sent it back and they "re-adjusted" it. They basically said I'm SOL since I daily mine and it is a race part.
It works great on the track, not so great partial throttle around town. Maybe I'll try another brand if it bothers me enough.
Old Oct 26, 2015 | 05:49 PM
civic-steve-94's Avatar
I purchased a k-tuned 90mm awhile back but have not ran it (still building car) the quality is awesome and the option to change the coupler to the throttle body with out any welding is awesome also.
Old Oct 27, 2015 | 12:45 AM
CO_RaceFab's Avatar
Skunks stick, accufab leaks, wilson hangs wide open on dyno with a huge spring. Ross machine seems to be working well
Old Oct 27, 2015 | 01:25 AM
Well sounds like they all got issues I've heard good things about s90 but they haven't released a 90mm yet
elnene_2012
May 30, 2016 08:33 AM
19992civichatch
Jan 19, 2007 04:24 PM
B18cHatch06
Mar 29, 2006 02:53 PM
bootlegtrader
Feb 5, 2006 09:04 AM
Sideshow9090
Dec 2, 2005 06:10 AM
