Engine no start, fuel related
Sup fellas a couple months ago I installed a killswitch on the fuel pump, today when I tried to start it it would start I flipped the switch to see if I forgot to turn it off and it still doesn't work, got out the DMM and it reads O.L in both switch positions with key on. I followed the wires to the connection above fuel pump and it still reads O.L all wires and fuses are fine . I'm wondering if the fuel pump is bad. Any similar situations you guys had? What's the next step
Fuel pump probably took a ****. Check the wires that run to the fuel pump and see if you get power. If you do get power but fuel pump dont come on, your stuff is done lol
dgdarien
Jul 19, 2017 05:48 PM
