car shutters and dies
Old Oct 22, 2015 | 09:22 PM
Srt.ej1's Avatar
Default car shutters and dies
i entered a tunnel on the highway, down shifted to hear my new straight pipe. and lost all power right after i hit the gas. i limped it to the gas station and then got it towed home. now the car starts fine but dies almost immediately. if i give it some gas it wont die right away but still ends up dieing. how do i diagnose if its fuel or spark? i can hear the pump prime but could it still be the problem? someone also mentioned i could have skipped a tooth on the timing belt, anyone know anything about that? im just a weekend mechanic, i have some knowledge but it aint much, let me know what you guys think, any feed back is very helpful. 94 civic si (d16)
Old Oct 22, 2015 | 09:46 PM
Jimster480's Avatar
Default Re: car shutters and dies
Sounds like it could have jumped a tooth.
Definitely sounds like a timing related issue.
Pull the timing cover and check the timing. There are grooves on the side of the cam gear.
Old Oct 22, 2015 | 09:53 PM
NotARaCist's Avatar
I never narc'd on nobody!
This is how you check timing. This is also where you should start.
Once you're done with that, buy a DEI/HEI spark tester, and follow the instructions on it. Tell us what color your spark is on all four. They look like this. $15 at your local parts store.
This is all extremely basic stuff. If you don't know how to do this stuff, I wouldn't recommend calling yourself even a "weekend" mechanic.
Old Oct 22, 2015 | 09:59 PM
Srt.ej1's Avatar
im just learning man. i can do those things forsure. is the screw driver spark trick the equivalent of the spark tester?
Old Oct 22, 2015 | 10:00 PM
Jimster480's Avatar
That also works to test spark yes.
Old Oct 22, 2015 | 10:05 PM
NotARaCist's Avatar
...Sure, if you want to risk your coil. Or, you could do it the right way, instead of the shade tree way.
Old Oct 22, 2015 | 10:18 PM
Srt.ej1's Avatar
i cant even get the cover off. its pitch black out and the tensioner seems to be in the way
Old Oct 22, 2015 | 10:23 PM
NotARaCist's Avatar
You don't have to remove the cover. There should also be a TDC mark on your crank pulley, and the lower cover. The tensioner sure as hell isn't what's stopping you from removing any covers, though.
hebrewhammer8
18
Jun 2, 2009 07:46 PM
92gs...92dx
12
Aug 15, 2007 09:31 AM
newbster
Oct 13, 2006 09:43 PM
GroundZer0 336
13
May 24, 2004 09:27 PM
slow99dx
May 20, 2004 12:49 PM
