2005 Honda Accord, passenger side window malfunctions randomly...
So as the title suggests, my passenger side window doesn't go up or down. when i push the switch on the drivers side or the passenger side i hear a clicking sound but the window doesn't budge. i have tried using a jumper wire on the master switch (drivers side; white/green wire with ground) but that didn't do anything.
However, I noticed that if i leave the car in the hot sun for a while (windows closed naturally) the window statrs working again, but then after i drive the car a bit it stops working. but sometimes it keeps on working for a while then stops. all at random. but if i leave the car in the shade for a while it stops working again. apparently heat or pressure inside the car, or both, does something. but what is it? what could the problem be?
my best guess is that its the main switch or a relay somewhere? is there a fix? would spraying some contact cleaner do anything?
tnmoghal
Nov 26, 2017 06:15 AM
hondagal2004
Nov 27, 2013 07:55 PM
bassichonda96
Jun 22, 2009 05:37 AM
