Rad fan not working
Old Oct 20, 2015 | 08:00 PM
Fraser1989's Avatar
Hey guys,
Looking for some guidance. My rad fan is not running, I did run a wire to the battery and it worked. I also did the paperclip trick to make sure the relay is working.
So from what I understand there are only two other things that could be causing the issue.
1 is the cooling fan switch, which as I understand it is the connector that plugs into the part I did the paper clip trick with.
Or it is the thermostat. Now since my engine temp goes down while I am thinking it is not the thermostat. The car only reaches high temps when it is sitting still and can regulate its temperature while driving.
So if someone can provide me with some insight as to what is the likely cause that would be great.
It's a 1999 civic cx hatch, manual without ac.
The cooling system should have no bubbles in it.
Changed the coolant and bled it last year. But I will re bleed it again as it is easy.
Old Oct 21, 2015 | 06:52 AM
Former User's Avatar
Default Re: Rad fan not working
Stock engine?
Bleed the cooling system.
Knightrider03m
Mar 17, 2015 05:50 PM
torino420
May 5, 2013 08:07 AM
nyhondaguy
Honda CR-V & Element
Dec 28, 2012 09:12 PM
mrader
Jun 13, 2010 06:35 PM
Flatlandz
Honda Civic (2001 - 2005)
May 2, 2010 12:32 PM
