civic fuel line leak suggestions
Old Oct 20, 2015 | 05:41 PM
swizz977's Avatar
Default civic fuel line leak suggestions
92 civic si
the line going to the fuel filter is leaking
honda has discontinued this line
what do you suggest i do?
Old Oct 20, 2015 | 05:53 PM
NotARaCist's Avatar
I never narc'd on nobody!
Default Re: civic fuel line leak suggestions
Buy new hardline. Bend hardline into the correct shape. Flare it. Done.
Old Oct 20, 2015 | 06:46 PM
Hondaciv866's Avatar
my question is this, cause i always wondered WTF i would do if some weird lines, as such as the op is mentioning, went on my car. Where would you buy these lines? any links? how would you know proper thread size etc? sorry for thread side track, but can this also be done with power steering lines that screw into the rack? where could one buy some new lines, bend/flare them, for the power steering to rack?
Old Oct 20, 2015 | 07:01 PM
NotARaCist's Avatar
It's just aluminium or stainless steel fuel line. You can get it pretty much anywhere. Just get line the same ID as the stock line, and you're good. The fittings are also easy to find all over the internet.
http://www.jegs.com/p/JEGS-Performan...53765/10002/-1
There's the line in 25" sections, you'd just need to measure the ID you need, then buy the fittings to go over it. You can rent the pipe bending, cutting, and flaring tools from most major parts stores.
Old Oct 21, 2015 | 12:30 AM
eghatch9295's Avatar
Stancetard Hate Monger
since its fuel, and low pressure (in the realm of pressure), you can safely use compression unions as well, if flaring scares you/you don't know how to do it.
Old Oct 21, 2015 | 02:15 AM
swizz977's Avatar
what about black nylon 6an hose
Old Oct 21, 2015 | 04:10 AM
rollinmyda's Avatar
That's possible but is one of the most expensive ways to do it and creates unnecessary steps because you need to change the other fittings to AN (and flare those lines as well), when there's no benefit to doing it that way. The cheapest and easiest way to do it is the way NARC suggested. Buy a couple new fittings, a section of fuel line, and bend and flare it to fit. It's actually really easy, just a little intimidating the first time you do it.
Old Oct 21, 2015 | 07:05 AM
swizz977's Avatar
ao do the whole line from the filter to this fitting in the picture?
Old Oct 21, 2015 | 11:16 PM
rollinmyda's Avatar
Yeah if you have to replace any section of line, replace the entire section. You don't want to add unnecessary splices into the line if you don't need to. From looking at your picture though you may have to replace the other side of that union too since it looks like your leak is happening at the union itself and not actually on the hardline. That's something you'll have to look at for yourself though because it's impossible to tell from a picture exactly where it's leaking.
Old Oct 23, 2015 | 01:56 PM
swizz977's Avatar
the guy i work with said we can just repair the line with a compression fitting
do u think it will hold?
Old Oct 23, 2015 | 02:18 PM
NotARaCist's Avatar
If it was done correctly, with hardware that's made to handle the proper pressure, I don't see any reason it shouldn't.
Old Oct 23, 2015 | 10:23 PM
oneheadlight's Avatar
+2 that actually looks well done, should be good!
Old Oct 24, 2015 | 12:51 AM
ITS_Dunn
Honda CR-V & Element
Oct 29, 2015 07:54 AM
deam760
May 19, 2007 09:53 AM
hybridmoments
Feb 15, 2007 07:55 AM
IMSTOCK
Aug 23, 2004 08:46 PM
PrecisionH23a
Jul 17, 2002 07:20 PM
