Maintenance on B18A1
Old Oct 20, 2015 | 03:20 PM
PUSHEMAN-em2's Avatar
Icon5 Maintenance on B18A1
Hey guys just picked up a DA9 project car doing some maintenance
to get things up to snuff. Does anyone have any suggestions on certain oil or filters they like to use on B18a1 engines? Or any suggestions to do like spark plugs, tranny flush etc.
Thanks
Old Oct 20, 2015 | 05:10 PM
Andrew7447's Avatar
Default Re: Maintenance on B18A1
everything.
Old Oct 20, 2015 | 11:02 PM
wunfstgsr's Avatar
Loved
Community Favorite
Thanks
Use OEM parts as much as you can my list of things would be,
OEM PCV valve
OEM oil filter
Penzoil or Mobil 1 is decent oil to use but its up to you really you dont need synthetic oil thats for sure.
NGK spark plug and wires no questions asked
new air filter
valve adjustment
tranny flush and use 2 3/4 qts of OEM Honda MTF
If any seals like cam seals valve cover seals need to be replaced use oem as well.
check brake fluid and clutch fluid and top off if needed.
GL
Old Oct 21, 2015 | 12:08 AM
Natsu09's Avatar
Also, distributor cap and rotor to pair with the NGK plugs and wires. Bonus; Check the battery terminals make sure they somewhat clean and aren't corroded. Check all belts for cracks, missing chunks, etc.
Old Oct 21, 2015 | 10:00 AM
Thanks guys that helps a lot
kidcool1977
Apr 19, 2008 05:27 PM
02z2899ex
Apr 18, 2005 12:16 PM
Comptech98GSR
Jul 27, 2002 04:29 PM
Total'd GSR
Jan 7, 2002 08:32 AM
