1992 integra taillights dont work.
Old Oct 19, 2015 | 08:10 PM
theseeker4's Avatar
Default 1992 integra taillights dont work.
My tail lights don't work when I step on the brakes at night but when I don't the lights are really dim. Please help
Old Oct 19, 2015 | 09:02 PM
Natsu09's Avatar
Default Re: 1992 integra taillights dont work.
Check to see if you have the right bulbs? The taillight bulbs are dual filament there is a possibility they could be burned out. Does your 3rd brake light come on when you step on the brakes? Have you messed with them?
Old Oct 19, 2015 | 09:21 PM
theseeker4's Avatar
ive checked all the bulbs there the correct ones. My back window light seems like its taking all the power because its on really bright but the tail lights aren't. And the wires are all messed up from the guy I bought it from.
Old Oct 19, 2015 | 09:32 PM
Natsu09's Avatar
Sorry to here that they are messed up. I would start trying to fix them. Have you checked the fuses to make sure they are not burnt out and the correct amps?
Old Oct 19, 2015 | 09:40 PM
theseeker4's Avatar
Ive tired to re wire them. But it seems like it don't do anything. Ive checked all the fuses and there good. But my left tail light the left bulb goes really bright and stays bright even when I step on the brake. Ive been looking for the harness with the bulbs but cant find it.
Old Oct 19, 2015 | 09:48 PM
Natsu09's Avatar
If you don't mind me asking how did you try rewiring them? Have you considered running new wires from the back of the fuse box (to the respectable fuse) to the tail lights? Essentially semi creating a new harness. Might be a real PITA, but worth it in the end.
Old Oct 19, 2015 | 09:54 PM
theseeker4's Avatar
I have no idea what I'm doing when it comes to wiring or anything with electricity. So I just got wire from a junk car and tried to run it to the bulbsockets from where the guy had cut the wires before. At first they were working fine. I had fixed the right tail light brake light, because before it didn't work. The all of a sudden the just stopped working. But I noticed that my back window light would go on and off when I wasn't even stepping on the brake. So idk what to do. My dad has a 90 integra ls and I want to ask him for his wiring but that's his daily driver.
Old Oct 19, 2015 | 10:06 PM
Natsu09's Avatar
Ah, sounds like a loose or bad connection. Then try to find an uncut harness or have someone make one for you. I would be careful you don't short something out.
Old Oct 20, 2015 | 05:12 PM
theseeker4's Avatar
Ill have to call local shops to see if they could make one for me. But ive been trying to look on the net and I cant find anything
Old Oct 20, 2015 | 08:59 PM
90Acura's Avatar
Probably not relevant to your situation, but FWIW at one time I would randomly blow tail light fuses. Turns out when someone in the past had installed a radio, there was a cut wire in that area that was wedged just perfectly so that the cut end was resting flat against the metal dash plate inner. Being a straight cut and not stripped, it would only occasionally short out. I could see something like that just barely touching, and being enough to dim lights but not blow fuses.
Simple rule for any wiring problems: Look for where someone's had there hands in there in the past, as factory work usually holds up well. Fixed at least 4 or 5 tail light problems on trucks/suvs years ago before factory installed trailer harnesses were popular, when people would install them and create problems with poor connections/shorts.
Old Oct 21, 2015 | 07:13 PM
theseeker4's Avatar
I just checked to see if any wires are touching and my fuse for the radio has a wire connected to it which leads all the way to the trunk. And that wire is touching the metal because the wire is cut and showing. So do you think that could be the problem?
Old Oct 22, 2015 | 03:50 PM
90Acura's Avatar
Definitely worth looking into. Probably at least half of the wiring problems out there are due to non-factory wiring, or someone having their hands in there in the past.
Old Oct 22, 2015 | 09:13 PM
wunfstgsr's Avatar
Loved
Community Favorite
Thats odd.. does it look like that wire was connected to any of the light bulb wires or even the harness for the tail lights? what do you mean that wire is touching the metal, what metal?
Sounds like maybe some one had that wire from the fuse to give power to maybe say the light bulbs.. aka ghetto rigged..
You need to post pics cause its hard to imagine whats going on from just your brief explanation.
Old Oct 22, 2015 | 09:20 PM
theseeker4's Avatar
Its from the radio fuse which leads all the way to the trunk. Which I think is for an amp for subwoofers. And its touching the metal under the carpet. And I'm just saying if that would bother anything. I'm not trying to sound like an idiot but how do I post pics on here it doesn't let me from my phone.
Old Oct 22, 2015 | 09:32 PM
wunfstgsr's Avatar
Loved
Community Favorite
Well if its not wired into the harness around the tail lights then no it wouldnt affect anything. If its not wired into a sub and just hanging there remove it you dont need that tapped into the fuse.
Make a account with photobucket.com its free. Then down load all your pics and organize them there. click a pic then on the bottom click the share icon and then click the links icon and then copy the IMG (for forums,boards) and paiste it in your post.
Old Oct 23, 2015 | 04:41 PM
Spartan117x's Avatar
Check the quality of the ground for that circuit. Incredibly IMPORTANT !!
BAd grounds will do just that.
Peace out..
Old Nov 2, 2015 | 09:36 AM
ben b.'s Avatar
Not sure how to resolve your problem but I have a 98 acura integra and dash light is out.
Can I connect the red wire (dimmer) and attach to ground to get illumination?
Fuses and switch test OK.
Old Nov 4, 2015 | 12:11 AM
wunfstgsr's Avatar
Loved
Community Favorite
You need to make your own thread after searching for your answer.
No! never ghetto rig something! ive seen integras catch fire from that exact reason! I mean why would want to do that instead of fixing it correctly. even at its lowest setting the dimer still gives light to the cluster so if its not lit up the dimmer is not your problem.
Its most likey your fuse thats gone out!
Cluttering and thread jacking some ones thread is not OK. And i just contributed to it a little just now.
tall007dfw
Nov 30, 2018 08:54 PM
Dat1BVtecN
Nov 14, 2007 08:43 PM
esp4life
May 9, 2005 08:38 AM
96GSR
May 19, 2002 01:08 PM
hobo79
13
Aug 13, 2001 05:30 PM
