Acura TSX Acura TSX Sports Sedan. USDM TSX and Euro/UK/JDM Accord.
Accord 5 speed trans into 06 tsx?
Old Oct 19, 2015 | 07:30 PM
thecruzs2007@yahoo.com's Avatar
Default Accord 5 speed trans into 06 tsx?
Whats up H-T! So my 6 speed transmission in my 2006 tsx seized up and does not roll all at even in nuetral. sounds like broken metal clunking.. I have come across a fairly good deal on an 2007 accord 5 speed transmission. now my question is will it bolt up to my chassis mounting locations? I've searched all over and have only found that they will bolt up to motor but haven't found anything on a confirmation saying they bolt up to chassis. Any info would be greatly appreciated. I would hate to have to source out another 6speed transmission.
Old Jan 1, 2016 | 08:42 PM
evertp1's Avatar
Default Re: Accord 5 speed trans into 06 tsx?
Yes it will bolt right up. The cases are exactly the same, only difference is that the TSX case is magnesium so its a bit light. The Accord 5spd USDM transmission case is the exact same case they use in the 03+ Accord Euro R. If you or someone you know is technically inclined, get them to take apart your transmission and take out the 6th gears and put them on the Accord shafts. Good Luck
GRAVEDIGGER
Jul 8, 2010 12:00 PM
the big read
Feb 22, 2008 01:48 PM
Alexnaderkeith
Jun 26, 2003 01:02 PM
accordmaui
Jan 28, 2003 03:40 PM
