Car won't start unless I jump it
Old Oct 18, 2015 | 05:58 PM
gcuck's Avatar
Default Car won't start unless I jump it
Any one still on this threatb?? If so im having the same issue i change n bought a new main relay, replaced fuel pump, and my pump dosent seem to prime at all... anyone please help. What should my next step be... i havea 94 with a d16z6 swap that i did myself. I was looking threw other threads n i saw it could b the ecu... i dont wana spend money on stuff i dont need.. plz help. Thank you
Old Oct 18, 2015 | 08:25 PM
NotARaCist's Avatar
I never narc'd on nobody!
Default Re: Car won't start unless I jump it
Sit down boys and girls, this is gonna be a fun one
https://honda-tech.com/honda-civic-d...sting-3002401/
First off, read that. Specifically, this part.
For all technical questions, the following information MUST be included in the first post: vehicle (year, make, model) and engine (if not stock, year, make, model, OBD type). Other pertinent information includes check engine light (CEL) codes as well as engine modifications, such as a turbo kit tuned at 18 psi or a specific throttle body, large injectors, big cams, etc. This information is absolutely essential because, in many instances, members wishing to help in a thread waste their time by posting detailed replies, only to find out the next day that the topic starter left out CRITICAL information. Please respect members wishing to help by taking the time to list or mention crucial information about your car.
Now fill in the gaps. Specifically, exactly what parts (and what write-up) you used to do your swap, and the status of the CEL.
Old Oct 19, 2015 | 03:00 AM
gcuck's Avatar
Ok so i have a 94 civic dx coupe. I resently change my dash harness to a 95 also obd1.. i pick it up a local junk yard because mine had the ecu stolen so they decided to cutt the pluggs off. I also purchased a 92-94 honda del sol motor a d16z6 ob1engine is all stock guy i bought it from said it was all pluggin.. wich it was , throthell all stock. Im curently on my way to work so i havent check the (CEL) is throwing off.. will have another post about it later today after 4 ocklock. Thank you.
gcuck's Avatar
If it matter i also purchased a p28 ob1 ecu for that motor
Jtadlock78
May 27, 2017 11:05 AM
mkhalid8
Jan 31, 2015 01:11 PM
Mora Long
May 10, 2010 07:08 AM
edm_jdm
Jan 2, 2008 05:45 PM
01IntegraSE
Mar 20, 2003 05:56 PM
