Vtec issue
Old Oct 16, 2015 | 07:55 PM
the rook's Avatar
Default Vtec issue
Anyone experienced a situation in which the vtec solenoid kicks in and it does so very loud. When it does the engine acts almost as if it loses power. Any help? Should I start by replacing the solenoid?
Old Oct 19, 2015 | 02:23 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: Vtec issue
Year, make, model, ECU, mods, check engine light on? You have to give at least this amount of info.
Old Oct 19, 2015 | 05:42 AM
the rook's Avatar
Of course. Sorry. It's a 2000 civic si. P2T ecu. No CEL. 142k original miles. No mods otherv th Han headers and cold air. I also noticed that the cruising rpm is higher by a bit than my d16y8. At 80mph I'm at 4500rpm in the 2000. My 91 hatch only runs about 3300. Just informing you in case they might be related problems.
Old Oct 20, 2015 | 09:41 AM
the rook's Avatar
CEL came on this morning on the way to work. Can't get it into the shop or to check the CEL til tonight. Car feels like I'm towing something. Couldn't get over 80 with it floored going up very small inclines on the highway. No smoke. No knocks. Cooling like normal. No smells or odd noises. Idles fine. Can't be vtec causing it. Clutch is new.
Transmission???
No slipping at all. Just weak as hell :-/
Old Oct 21, 2015 | 06:57 AM
the rook's Avatar
CEL came on yesterday. PO170 and PO172.
O2 and map sensors are new and working. My hp and torque are in the toilet. Can't maintain speed uphill. Not even able to downshift to do so. I only have dc headers and dc exhaust system with a new cat, and dc cold air. No other mods. I guess I'm gonna shop it. It's a fuel air delivery code. Would that cause such a drastic loss of power? Like I said before, it feels like I'm towing a trailer. Lol.
Oh, and no missing or misfiring that I can tell.
Old Oct 21, 2015 | 01:38 PM
the rook's Avatar
Could b it also be possible that the problem is that the ecu is not functioning properly because of the headers? Maybe I need to program my ecu in order to bypass the o2 sensors. It's and OBD2. I have an OBD1 at home that I can order a basemap chip for and a conversion harness.
Old Oct 24, 2015 | 12:04 PM
the rook's Avatar
So I had the problem fixed and I wouldn't have guessed it. I realize I'm the only one on this forum but maybe it'll help someone down the road. Turns out that the first denso o2 sensor went faulty. At that point the flooding of the motor began to clog the cat. The cat, which was relatively new, was ruined and needed replaced. Put a Magnaflow high output cat on and problem solved!!
Old Oct 24, 2015 | 12:16 PM
oneheadlight's Avatar
sorry I'm late to your post, but I can back up what happened to you. As it happened to me. I replaced my primary o2 sensor, and the new one was faulty causing surging at higher speeds, lack of acceleration, etc. Luckily it wasn't running rich but lean on mine so the cat wasn't destroyed. I replaced it with another new o2 sensor, this time it was working properly.. but..Glad you were able to fix yours!
Old Oct 24, 2015 | 12:57 PM
the rook's Avatar
Yeah I ran through a lot of potential problems in my mind and I investigated before I shopped it. I'm just glad it was something simple.
ek951
18
Apr 17, 2012 12:09 PM
Vtecruddy
Mar 17, 2011 03:41 PM
05r1
16
May 20, 2005 08:21 AM
lilxvtecxpwr
Jan 18, 2003 08:06 PM
B18C-Hatch
Aug 31, 2002 02:04 PM
