Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
03 Civic Evap Leak Detected p1457
Old Oct 16, 2015 | 12:29 PM
mountain-dewman's Avatar
Icon2 03 Civic Evap Leak Detected p1457
~I just joined and this is my first post.
I have an 03 Civic with Check engine light on P1457, I have been dealing with it the past year now. I did hours of research and attempted to fix this but cannot figure out the problem.
Parts I replaced:
-new canister vent shut valve (non-OEM but Dorman brand)
- evap solenoid module (they updated this part, I got the new one with 3-way joint)
-OEM fuel cap
-replaced evap canister (got another one used as I thought it was the problem)
When I open my gas cap, pressure is coming out, so I would think there isn't a leak. With this code, my car will stumble sometimes when accelerating, I have to push the accelerator further down for it to go.
-In the beginning of a day I will drive the car somewhere and drives fine, no stumbling issue. I come back like an hour or so later, starts up fine, but as I go a little bit it the acceleration cuts out like 3 or 4 times. I press the accelerator down farther when its cutting out so it goes, then finally no more and am driving good rest of way where I am going. The stumbling will happen the rest of the day each time I start it up and drive, same 3 or 4 times then driving fine. Next day the whole cycle repeats itself.
-I don't know where to look next or what the problem could be, any ideas?
Old Oct 16, 2015 | 01:03 PM
JDM_G35/EX's Avatar
Default Re: 03 Civic Evap Leak Detected p1457
There is 2 codes related to the evap p1457 and p1456 The (p1456 is the gas tank location including the gas cap) since u have already replaced the gas cap and you are still getting a p1457 looks like it is the other half of the system where the charcol canister is located. most likely it is your evap bypass valve/solenoid.
What I would do is replace those 2 things and see if that clears the code otherwise, I’m sorry to tell you my friend but I think you may have another problem.
I hope this helps you some
Good luck
Old Oct 19, 2015 | 06:18 AM
NDNV's Avatar
I solved the P1457 code by replacing the EVAP by-pass shut valve (and canister since it is difficult to separate and old anyway) under the vehicle. All OEM Honda parts.
David Lochhead
Honda Civic (2006 - 2015)
Sep 8, 2018 03:20 PM
raider1qaz
10
Jan 30, 2014 07:06 PM
Rhondasgold
Mar 5, 2011 03:11 PM
xroadrashx
36
Jun 1, 2004 08:03 AM
SlowHatchback
Jun 25, 2003 01:26 AM
