Help! Coolant In Transmission Fluid
Old Oct 16, 2015 | 06:27 AM
ashtonallen's Avatar
Default Help! Coolant In Transmission Fluid
I have a Honda Accord V6. I have been slowly leaking coolant for 2 months and couldn't find the leak. I put some tracer dye in the radiator. The transmission fluid lit up light a Christmas tree. Will you please advise the best course of action?
Old Oct 16, 2015 | 07:30 PM
DC4KiD's Avatar
Default Re: Help! Coolant In Transmission Fluid
You may have a bad radiator (assuming you have an automatic). The stock transmission cooler is built into the bottom part of the radiator. If it internally fails, you'll have coolant and ATF mixing. Coolant in your automatic transmission will mean death to the clutch packs. Please fix it before you have a bigger issue to take care of.
Old Oct 18, 2015 | 04:12 AM
Are you sure that is right? There are no cooler lines coming out of that radiator.
Old Oct 18, 2015 | 06:52 AM
saukrateaz's Avatar
If looking down at the radiator, doesnt the return line run from the drivers side of the radiator across and over the top of the trans?
Old Oct 18, 2015 | 07:08 AM
spAdam's Avatar
Loved
Community Favorite
Other way around. There Are transmission lines running to the radiator. Should be two lines at the bottom, at roughly opposite ends of the rad.
Old Oct 18, 2015 | 08:28 AM
This model has a transmission warmer sitting on top of the transmission. I thought that since it has this design, no transmission flows to this radiator? Is that wrong?
Old Oct 18, 2015 | 10:24 AM
spAdam's Avatar
Loved
Community Favorite
Maybe? You made no mention of the year/generation.
Old Oct 18, 2015 | 11:07 AM
Sorry 2007 accord v6 lx. Does anyone know the steps to take on this model when finding coolant in transmission fluid?
Old Oct 18, 2015 | 02:01 PM
civic-steve-94's Avatar
Same thing you do with any vehicle that does this buy a new radiator and flush the hell out of the cooling system
Old Oct 18, 2015 | 02:11 PM
That's where I'm getting confused. It seems like the heat exchanger/transmission warmer is the part I should replace. Isn't that where the breach would have occurred? Should I replace the radiator just in case it's bad too? Am I altogether mistaken thinking the transmission warmer is the failed part?
Captncrusade
Apr 16, 2016 10:09 PM
jwarren1904
Nov 21, 2013 11:58 AM
Prelude209
Oct 11, 2010 12:48 PM
slikz714
Jul 12, 2006 03:40 AM
BoostedGSRBubble
May 26, 2002 02:39 PM
