Code P0108...smh
Old Oct 15, 2015 | 07:35 PM
blackj30_a's Avatar
Default Code P0108...smh
So my car has been sputtering upon take off so while getting the oil changed I had the code read which was a P0108. Upon reading most of the material that came up said it was the map sensor. Is it a hard part to repair and where is it at to begin with lol. Thanks in advance
Old Oct 15, 2015 | 08:14 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: Code P0108...smh
Verify that it is not the sensor itself by testing it with a vacuum gauge and verifying the wiring is not damaged. Check the main engine harness ground as well.
Code could be set if the wiring is damaged, there is a vacuum leak to the sensor, there is a vacuum leak in the intake manifold(reducing signal resolution), or even a worn engine that is loosing compression.
Sensor on F22s is is usually located on top of the TB/intake manifold and will have a 3 wire connector to it.
^like so.
Old Oct 15, 2015 | 08:26 PM
blackj30_a's Avatar
Where wound the sensor be on a 99 j30. And thanks for the quick reply
Old Oct 15, 2015 | 08:30 PM
MAD_MIKE's Avatar
MM Gruppe B
It will be similar placement on the J30. Look at the TB there will be a three wire sensor on top of the TB.
Old Oct 15, 2015 | 08:32 PM
blackj30_a's Avatar
Ok cool. I appreciate the help. I'll keep you posted on what the outcome is
Old Oct 16, 2015 | 05:50 PM
blackj30_a's Avatar
Just now looking for the map sensor and it is right on top of my throttle body. Haven't fixed it yet but I'll still stay posted if it works out. Can you clean those or is it just better to replace it
Old Oct 19, 2015 | 07:44 AM
blackj30_a's Avatar
Got it switched out. The sensor was about $78 at autozone now it's back to normal. Thanks for your help
sinceasar
Jan 25, 2013 04:17 AM
SoHc94
Sep 11, 2006 08:58 PM
Groove_D
May 27, 2006 11:40 AM
dalecrx
Apr 6, 2006 07:19 PM
underage
Jul 13, 2005 02:33 PM
