Help me!!!! My gsr is jerking all over.
For about a month now at low rpms and almost no throttle the car starts to jerk untell I give it gas. This problem really sucks because I look like a non driving *** in parking lots. Does not change over any speed. Only thing that makes it go away is more throttle.
Please help me!!!!!!!!
ok I driving home from work and it starts jerking again. So I push in the clutch and slowly start to bluid rpms. And at about 3 grand the tach takes back off to 1 grand with no change in throttle. After I would pass 3 grand the problem went away.
Help me please
Help me please
this happened to me a long time ago in my 88 626. i just gave it new spark plugs and wires... after i replaced this, the car stopped jerking. but.. you mite other probs. i'm just tellin u my experience.
i had a similar problem in my civic where my car would dog super bad at low rpm, then when it reached 3kish, it would start driving normally. at first it would do it occasionally, but the severity and frequency got worse. i found that my air temp sensor had come loose out of my intake. i popped it back in, reset my ecu and it was fine. i think it was slowly coming loose, then finally came all the way out hence the growing problem.
hope that helps.
hope that helps.
could be a couple of things, sounds like ignition though. Start with changing the plugs and wires, then move on to a coil, make sure you have no cheack engine lights, and if you do then no guess work. HOndas are simple, just try to think about it.
lmsem1
Feb 14, 2010 12:17 PM
TiMiD703
May 15, 2007 08:59 AM
