Accord ex vtec f22b1 or 2??
Old Oct 15, 2015 | 05:01 PM
ZAccord96's Avatar
Default Accord ex vtec f22b1 or 2??
Im trying to figure out if my accord is f22b1 or f22b2 is the only difference vtec or non-vtec??
Old Oct 15, 2015 | 08:08 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: Accord ex vtec f22b1 or 2??
If you have a factory USDM 94-97 Accord if it has VTEC it is the B1 engine. Valve covers of VTEC engines usually have 'VTEC' cast into the cover.
Valve covers are NOT interchangeable, so a B2 cannot have a B1 valve cover.
Old Oct 15, 2015 | 09:23 PM
silverone's Avatar
I apologize for for hijacking here but I wondering how to find out the engine code for our 2001 accord v-tech 4cyl .
Thanks!
Old Oct 15, 2015 | 10:44 PM
MAD_MIKE's Avatar
MM Gruppe B
Pretty simple.
Look at the water outlet that is facing the radiator(not the thermostat housing), now look under it.
On the engine block there will be a raised embossed casting. It will be F23A#. If the block is heavily corroded you may need some scotch brite pad clean/clear it to read the casting.
Google image it if you are still unsure.
Old Oct 16, 2015 | 07:47 AM
ZAccord96's Avatar
Thanks mike thats what i thought just needed to make sure its the B1
Old Oct 17, 2015 | 06:02 PM
silverone's Avatar
Pretty simple.
Thanks M.M. I'll check it tomorrow.
Scoberdoo
Sep 5, 2018 08:31 AM
TRG
Feb 3, 2009 05:30 PM
blackbmagic
Feb 14, 2005 04:23 PM
bad93ex
Jul 26, 2002 11:37 PM
