1991 acura integra ls hatch
I'm soon going to be acquiring a 91 Integra ls 2 dr hatchback its some serious problems the timing belt shredded while In motion and the camshaft is locked im not sure about how sever the engine damage is but I plan on swapping a whole new engine I saw on hmotors there was a 88-92 zc sohc long block that would have everything I believe but I dint know if the transmission would need to be replaced too the transmission o. The site is a 5 speed zc transmission. Is that automatic ? Cause the car is automatic. Thank you for reading and hope to get some helpful responses also sorry for any mispellimg I can't see what I'm typing on my phone for some reason
Dude, the b18 a1/b1 is really a good motor. no its no k series or vtec but it has perfect compression and with a bottom end build you have a machine that can be perfect for a turbo. 9.2:1 Stock compression ratio is great news for a turbo guy. I've priced everything out and reliability and power wise its silly not get another b18 a1/b1 here's just one option for a builder if you need a complete or a longblock Acura engines & short blocks. I don't know his reputation but it goes to show 1700.00 for a complete rebuilt with .25 0versixed pistons isn't bad...look around and you'll be surprised
I would build the block yourself if your motivated and can teach yourself what you need to know all the info is here on line just dedicate some hours to picking it all up. on the internet time is money the more time you spend learning and understanding the more money you save if you don't cut corners
Best case scenario the belt just needs to be replaced if the engine was at a low rpm when the belt snapped or the valves are bent and just need the head pulled off and repaired or you might have a cracked piston along with the damaged head...
If your not mech inclined replace the engine and call it a day, just find another LS long block or even a b20 long block and slap your transmission on it and your golden. A snapped belt won't affect the transmission.
G2IC: Teg Tips
heres a good starting point google everything and ask lots of questions...
Not related to this post, but recently bought a 92 teggy with a b18a1 in the car was automatic now manual. When driving the car it doesn't go into 2nd smooth has a little delay before it will let me shift in and reverse is a little tricky to shift into. Do you think its a throwout bearing or maybe a nice fluid flush and fill will do the trick.
Thanks
Thanks
Thanks
Thanks
Search the faq
a throw out bearing....that's not the issue...It could be a bunch of things...is it hydraulic or cable and what about mounting is it all done properly.....it could be bad syncros so many possibilities your gonna have to do some homework....if you think it's the throw out bearing I wonder why ow you completed a auto to Manual swap did you do it alone???
Its great to want to help but its better for him to make his own thread if he feels the need to from not finding his answer searching. Then we will be happy to help him.
JDMefHATCH7
16
Oct 30, 2009 07:06 PM
