B18C5 12.2-5:1 CPR Arias ,CP ,JE ,Or Wiseco pistons?
My build will be a CRX 2nd gen with a a basic summary of the engine build is a B18C5 81×89 With a knife edge'd Crank Brain Crower 'H beam' Rods with high compression pistons 12.2:1 or 12.5:1 compression pistons depending what ideas i get for a B16/ITR head setup for valves ect.. (suggests would be nice for a head setup ) ARP rod bolts, Main stud bolts, head stud bokts, flywheel & Pressure plate bolts, Crankshaft pulley bolt & tensioner Bolt.the rotating assembly will be ballanced & for the tranmission ill be useing a Integra Xsi LSD tranmission with Carbon Syncros,
boostd ls
Feb 5, 2006 01:10 PM
