coolant leak under intake manifold
So I just finished installing my new d16a6 head on the hatch, I started it a couple days ago for a few seconds without coolant to make sure the timing was exact, but today as I was filling it up with coolant (with-out the car on) I noticed coolant was dripping of my exhaust flange. When I looked closer, the leak was coming from under the intake manifold, could it be my waterpump?
What? Your motor geography doesn't make any sense. If your water pump is leaking how would it leak from your intake manifold and down onto the exhaust? If the leak is that bad from just filling the coolant without the car on I bet it'll be really easy to find. Get a flashlight or takes pictures can't help with something so generic.
Sounds like you need a new intake manifold gasket. There is a small port where coolant runs through that can leak, it happened to me with 2 new aftermarket gaskets before a new oem gasket cured it.
thank dude ill take out the manifold today and post pics, loved your crx build thread btw
Could be the coolant pipe on back that is leaking too. The thermostat housing side does have an o-ring on it.
Also I would recommend pressure testing the system before just tearing it apart.
thead
Aug 31, 2012 07:47 PM
holmesnmanny
Jun 9, 2012 11:33 AM
Nobody123
Dec 22, 2011 05:16 PM
