stock(nachi) vs. exedy supplied(nsk) throwout bearing pics
Old Nov 5, 2002 | 05:15 PM
woodog's Avatar
Default stock(nachi) vs. exedy supplied(nsk) throwout bearing pics
smitdog received his exedy clutch today and i thought i'd post some comparison pics between his exedy supplied throwout bearing(nsk) and the stock nachi(which he will be using over the nsk).
nsk is on the left and nachi is on the right.
could this be the source of problems associated with exedy clutches?
Old Nov 5, 2002 | 05:21 PM
Smitdog's Avatar
Default Re: stock(nachi) vs. exedy supplied(nsk) throwout bearing pics (dc2R320)
Yes I am going to use the NEW Stock Throw Out Bearing with my Exedy Clutch. I have heard many problems and I know guy MISFIT who also used a NEW stock Throw Out Bearing and he has not had one problem with his Exedy Organic clutch! Clutch goes in tomm so i will keep everyone posted!
Old Nov 5, 2002 | 05:36 PM
rainmanEK's Avatar
big strong guy
Default Re: stock(nachi) vs. exedy supplied(nsk) throwout bearing pics (Smitdog)
interesting!! thanks eric
Old Nov 5, 2002 | 05:39 PM
Misfit's Avatar
Default Re: stock(nachi) vs. exedy supplied(nsk) throwout bearing pics (rainmanEK)
i would that guy he is talking about. i am having no probs here
Old Nov 5, 2002 | 05:50 PM
Tommy_Gunns's Avatar
Interesting. How much is a new OEM throwout bearing? Can the old one be re-used?
tranny newbie.
Old Nov 5, 2002 | 05:52 PM
Misfit's Avatar
Default Re: stock(nachi) vs. exedy supplied(nsk) throwout bearing pics (Tommy_Gunns)
its like 20-30 bucks or something like that
Old Nov 5, 2002 | 05:54 PM
Default Re: stock(nachi) vs. exedy supplied(nsk) throwout bearing pics (MISFIT)
If that's the case, new one it is.
Old Nov 5, 2002 | 05:55 PM
Misfit's Avatar
i have a reciept somewhere i will find it and let you know.
Old Nov 5, 2002 | 05:59 PM
Thanks man!
Old Nov 5, 2002 | 07:18 PM
canuckr's Avatar
What kind of problems are u talking about? I am also using a exedy organic clutch and having some problems with notchyness(sp) when shifting. Would the throwout bearing have anything to do with the problem I am expirencing?
Old Nov 5, 2002 | 09:11 PM
mstewar's Avatar
thanks guys for getting those pics up.. now i see the difference.. hmm.. let me know what happens tomorrow man.. good luck!!
find out anything on the release bearing thing we were discussing?
nice having the new clutch/flywheel sneaking into the pics too.. exedy goodness..
[Modified by mstewar, 1:12 AM 11/6/2002]
Old Nov 6, 2002 | 03:26 AM
Smitdog's Avatar
Default Re: stock(nachi) vs. exedy supplied(nsk) throwout bearing pics (mstewar)
Clutch will go in today around 5, so I will post later tonight and see how it goes. Many people I know jave ahd to adjust the push rod ont he floor right away when installed or when totaly pushing the pedal in there is a grinding noise. And just other poblems in general too.
The stock throw our bearing was $37 dollars at my employee price at the Hond Delaership I wrok at. I will get the part number and post it lata along with how things went with the install and first drive home with the Exedy!
Old Nov 6, 2002 | 03:49 AM
Asahi's Avatar
Default Re: stock(nachi) vs. exedy supplied(nsk) throwout bearing pics (canuckr)
Unlikely. Tried adding tranny fluid or changing if needed? What fluid are you using?
Old Nov 6, 2002 | 03:51 AM
Asahi's Avatar
What problems with the exedy clutches are you guys referring to? I have absolutely no trouble from mine with the exedy throwout bearing. You can have a little more travel than needed but this is easily adjusted using the helpes section 12.3 (I think). Is there bearing failure I have not heard of or just the minor problme with the PP fingers hitting?
Old Nov 6, 2002 | 06:34 AM
canuckr's Avatar
Default Re: stock(nachi) vs. exedy supplied(nsk) throwout bearing pics (Asahi)
I have changed the tranny fluid with honda oil.
Old Nov 6, 2002 | 10:45 AM
mstewar's Avatar
same thing I said when Smitdog told me about people having problems.. I haven't heard of any..? i like mine!
Old Nov 6, 2002 | 10:48 AM
done's Avatar
What about action, i just got much clutch in..
sorry for quality of pics
Old Nov 6, 2002 | 10:50 AM
done's Avatar
Default Re: stock(nachi) vs. exedy supplied(nsk) throwout bearing pics (Jordo)
just looked at it, my throwout bearing looks like stock.. its nsk though
Old Nov 6, 2002 | 12:18 PM
ILUVTEC's Avatar
I've got the Action Stage 1KS Clutch kit, and I love it, I believe I used the throwout bearing supplied with it vs the old stock one, not sure though, enjoy
Old Nov 6, 2002 | 01:56 PM
non-VTEC's Avatar
the bearing i got with my exedy clutch is exactly the same as the stock one.......i got mine clutch kit from clutchcityonline.com
the bearing i have looks exactly like the one pictured on the right...........i dont know who or why they sent you the one on the left for......it looks like the wrong one for a integra tranny.......
Old Nov 6, 2002 | 04:40 PM
done's Avatar
Default Re: stock(nachi) vs. exedy supplied(nsk) throwout bearing pics (non-VTEC)
the one i got is action 2ks
Old Nov 6, 2002 | 04:43 PM
Smitdog's Avatar
Well clutch is in. It took 1hr 50mins to install and car back on the ground and running.
First start the car and all is fine but then push the clutch pedal to the floor and in makes that slight grinding sound. Not as bad as others I have heard. Adjusted the push rod under the dash like it says, and the the grinding went away. Thing i really dislike is that u must shorten the rod therefore making the clutch pedal have alot less play in it which i did not want!
Drive home and the clutch feels likes stock grabing wise. I am goign to wait till about 400miles to see how it really grabs.
Then pull i the garage and leave it running and put the windows down and puch the clutch pedal all the way in and then again a very slight grinding noise. Tightened the push rod bolt tightly, so that could have not moved on the way home, so I am wondering why it is grinding again? Like i said bearly but still any of that is a no no!
Old Nov 6, 2002 | 04:47 PM
Misfit's Avatar
hell mine kinda grinds. i need to adjust mine. i guess i will just live with it. its only with the clutch all the way in. so i rarely hear it otherwise.
Old Nov 6, 2002 | 05:11 PM
Smitdog's Avatar
I dont want any grinding i am too ****!! See i piaid this money for a new clutch I dont want problems. I know so many people like the starter of this thred DC2R320 that bolted in there ACT HDSS and have not a single problem!
Old Nov 6, 2002 | 05:27 PM
Asahi's Avatar
1 hour 5 minutes from start to finish? From jacking up to putting tools away? It took the We -todds with 4 of the most experienced people I have ever seen going nuts to pull my tranny in 45 minutes. It woudl have taken them just over 1.5 hours if they had worked at that frezied pace the whole time and not done the FD swap.
Took us 4.5-5 hours to do a clutch install on an Si and that was working steadily.
You guys got a ninja trick?
