h22 keeps dying while driving
Old Oct 6, 2015 | 06:47 PM
willfly's Avatar
Default h22 keeps dying while driving
For some reason my h22 wont keep a charge I had battery and alternator tested and both are good. So I put both back on vehicle and drove car for about 10miles and lights went dim then car died I tried to restart and it just clicked wtf could it be?
Old Oct 6, 2015 | 08:24 PM
holmesnmanny's Avatar
Default Re: h22 keeps dying while driving
It's likely the alternator is bad. You need to test it yourself. With all accessories loaded up it should be putting out about 14 volts. If not, it's bad.
Parts stores can't properly test Honda alternators. Period.
Old Oct 8, 2015 | 01:21 PM
willfly's Avatar
Could it be a fuse? If so which one?
Old Oct 8, 2015 | 01:43 PM
hybridmiklo's Avatar
you running an aftermarket alternator relocator?
Old Oct 8, 2015 | 03:26 PM
willfly's Avatar
No
Old Oct 9, 2015 | 07:48 PM
If it's a fuse it's going to be the big 80a/90a fuse in the engine bay fuse compartment. It's a big fuse.
Old Oct 10, 2015 | 02:12 PM
do you have a multi meter and know how to use one? If so I can show you how to test the chargin system. If not, take it somewhere or to someone who does
Old Oct 10, 2015 | 02:41 PM
hondamike42's Avatar
YA PARTS STORES CANT TEST STARTERS OR ALTERNATORS, WHEN STARTERS GET HOT THEY STOP WORKING , ALTERNATORS PROBABLY TOO, MAYBE THE INTERNAL VOLTAGE REGULATOR IN ALTERNATOR, TEST THE AMP OUTPUT, ALSO MEASURE VOLTAGE DROP POWER AND GROUND
Old Oct 10, 2015 | 04:09 PM
willfly's Avatar
[QUOTE=hondamike42;50571153]YA PARTS STORES CANT TEST STARTERS OR ALTERNATORS, WHEN STARTERS GET HOT THEY STOP WORKING , ALTERNATORS PROBABLY TOO, MAYBE THE INTERNAL VOLTAGE REGULATOR IN ALTERNATOR, TEST THE AMP OUTPUT, ALSO MEASURE VOLTAGE DROP POWER AND GROUND[/ QUOTE]I don't have voltmeter but I replaced alternator and charged battery and its still doing samething..I used a test light on the alternator plug and 3 of the 4 pins lit up. Should all 4 pins lite up
Old Oct 14, 2015 | 04:07 PM
test light is not going to help you. Those are only good for checking fuses, since you need to know exactly how much voltage is present. If you cant get a voltmeter take the car somewhere else. You are just going to keep throwing money at it hoping it will fix it.
lakeviewman
Aug 8, 2025 02:07 PM
H22poweredEJ8
15
Nov 6, 2007 05:08 PM
Syndacate
32
Jul 12, 2007 09:08 AM
phase7
Feb 20, 2007 07:16 AM
