Help with 97 accord lx with h22a7 swap
Hello,
So I have a 97 accord LX, I have installed an H22a7 w/ trans. Bolting it in was no problem. I used the stock vehicles obd2a wiring harness. I have a jumper harness going to a p28 chipped obd1 ecu. I rewired the injector connectors the new H22a7 injectors. The alternator I swapped out the connectors so the stock wiring connections are used. The idle air control I have to get the adapter plate and relocate it. I got the rywire sub harness for the distributor. My issue is its at crank no start.... I have the external coil connector jumped. I have voltage all the way to the coil but nothing coming out of it... I have the H22 distributor installed TD94U.. A question I have is can I use this distributor? Is there anything I should check? Plz help so close to finishing
rorik
Aug 18, 2016 04:51 PM
Speedfiend97LX
Jun 3, 2011 10:20 PM
