Harmonic Balancer Wearing into Timing Cover and has Erased Ignition Timing Marks
Old Oct 6, 2015 | 12:16 PM
JPhilBradley's Avatar
Icon2 Harmonic Balancer Wearing into Timing Cover and has Erased Ignition Timing Marks
OBD-1 B18C1
'95 GSR Sedan
As the title states my crank pulley/harmonic balancer is wearing into the timing cover and has erased my timing marks.
At first, I thought the crankshaft thrust washers were worn out, but when using a pry bar I can't get any thrust out of the crankshaft.
I spoke with a co worker and he informed me that he had seen the rubber on import harmonic balancers wear out more than once, and for some reason it always seems to collapse towards the engine, which would explain what I have going on.
My question: Anyone here experience this before? How do I tell if my balancer is worn out? What are my options for replacement?
Old Oct 6, 2015 | 08:26 PM
holmesnmanny's Avatar
Default Re: Harmonic Balancer Wearing into Timing Cover and has Erased Ignition Timing Marks
Over time the pulley does wear out and it starts to separate from itself. They have aftermarket options if you can't find a used one. New ones aren't cheap but you can go the route from Honda if you choose.
Old Oct 7, 2015 | 10:12 AM
Ever seen one wear into the timing belt cover?
Old Oct 7, 2015 | 02:27 PM
v4lu3s's Avatar
RTFM
usually that is a result of the plastic cover slowly warping over time not the pulley. I have seen it happen on D, B F and H series.
Old Oct 7, 2015 | 02:40 PM
Icon2 Re: Harmonic Balancer Wearing into Timing Cover and has Erased Ignition Timing Marks
Interesting. I think I'm going to buy a new one, install it, and see what I'm out. If it's touching I'll start looking elsewhere.
Anything else I should replace with the Timing Belt Covers? Timing Belt & Water Pump were replaced ~30,000 miles ago so I should be good there.
Old Oct 7, 2015 | 04:04 PM
v4lu3s's Avatar
RTFM
just eyeball it all and make sure its clean. When that rubber ring goes out the outer pulley gets WAY loose and can be seen moving easily, if not coming off almost completely.
londoncrx
Mar 6, 2011 06:30 PM
SilvrBullet GSR
Nov 20, 2007 12:42 PM
NSfit
Nov 26, 2006 07:34 PM
Honda Kustums
Aug 19, 2003 06:36 PM
Brian_92GSR
Aug 19, 2002 07:23 AM
