93 accord, no spark, cel stays on
I put new timing belt and water pump on it. Now no spark, check engine light stays on constantly. the D4 light is blinking. I just installed a new fuel/master relay. jump the plug to get blink codes, cel wont blink, stays on constantly. the D4 light gives blink codes
was a good driving car till now.
I did double check the ground at the thermostat its good
What about the crank position sensor? Are you sure everything is lined up and connected? I would suggest going over the job completely and see if there's anything that you forgot, specially because you said the car was working fine before that.
MuthaFodder
Mar 26, 2025 07:42 PM
sippyaccord
Aug 18, 2018 11:09 AM
Linked
May 16, 2010 11:20 AM
dblack
Apr 15, 2004 09:05 AM
