Please read the rules for the new thread. At the end of each month this thread will be unstickied, and a new thread created in this one's place. If you haven't sold your parts, you may post them in the new month's thread. DO NOT BUMP THE OLD THREAD
1) This is for RaceCar parts ONLY. No body panels, fenders etc allowed, unless it is a full race front end. ABSOLUTELY NO useless OEM parts! 2) Do NOT repost your thread over and over hoping to get it on a new page. If your parts sell please remove them from your post. If you sell everything off of your list of parts, report your post to moderator by clicking on the just under your user name and we will delete it. 3)You are ONLY allowed ONE post in this thread. If you are found to have more than 1 post, in the FS sticky all of your posts in the sticky will be deleted, and you will be given an infraction. With enough infractions you will be banned 4) NO WTB ADS! 5) NO COMMERCIAL POSTS AT ALL THIS MEANS, IF YOU OWN A SHOP DO NOT POST BRAND NEW PARTS IN HERE 6) Please provide all pertinent information, including price, and try to return pm's.
We will delete any BS we feel does not belong in here
Please try and limit the size and # of pictures you post. using thumbnails would be fantastic.
From this point on, 3-7-2012, any edit mods have to make to these threads, will result in sanctions. if it persists, the stickies will disappear for good. THIS WILL BE ADHERED TO. No more warnings
-Borg Warner S300 SX S300SX 91/79 .91 A/R w/ Full Race v-band. $600
-2 Bosch 044 fuel pumps with T1 mount. $390
Crower B-series stage 2 turbo camshafts $300
Honda / Acura - B16A, B17A & B18C
Performance level - Stage 2 - Forced Induction Special Designed specifically for turbo/blower. Features short duration, low overlap and high valve lift. Requires kit #84161.
INT/EXH - Dur @ .050” Lift: °/° RR: 1.55/1.55 Gross Lift: ”/” LSA: 108° RPM: 1500 to 9500 Redline: 10000
Crower b series valve springs, titanium retainers and keepers. 85lbs. sold
-MSD pro billet distributor with driver, coil, and wires. $399
-Edelbrock Fuel rail $80
-NRG short steering wheel hub EG $70
-8 ARP extended wheel studs new $45
-some knock contraption I bought some years ago never used $85
-Intercooler 31" X 12"X 4" 3" inlet and outlet brand new. $155
-Autometer 3 3/8 pro comp carbon fiber speedo, mounted never used. $200
-Autometer 3 3/8 pro comp carbon fiber Tach, mounted never used. SOLD
-Autometer 2 1/16 pro comp Fuel level gauge, works with stock sending unit, mounted never SOLD
-random HKS boost gauge. JDM yo! $35
-R-Crew 3" turbo back Exhaust 92-95 civic really great quality slip on type fitment adjustable, 3" all the way through with vband connection. I've used this on a 96 del sol that means it also fits del sols. I had to relocate the center hangers to fit. perfect fitment, I am selling only because I'm upgrading to 3.5" on the EM1 else I would mod it to fit. $450
-Custom made 3" Vband top mount turbo downpipe wrapped in DEI titanium wrap with one O2 sensor bung, and one 1/8 npt I used for EGT. goes great with above exhaust system. $200
Will not part out 1000hp turn key set up minus the dogbox and axles. It's a complete package will post pictures specifics will be upon request. Car made 455fwhp at 13 psi at 1 mile elevation on e85. Will attach link, have receipts for most parts
Looking for 9.5kobo
95 civic coupe EX shell decent shape
*B18 dart block 81.5 bore*
-cp pistons
-LS transmission
-Act clutch not sure strength have pictures.
-Eagle "Hbeam" rods
-acl bearings main and rod
-orbit high performance oil pump -Arp2000 cap screws.
-Arp head studs
-Cometic .51 Head gasket
-Cometic bottom end gaskets kit
-Brian crower valves and dual springs. -Crower retainers and clips.
-Bc n/a stage 3 cams good for 1000 new.
-new Bc cam gears
-Moroso oil pan new.
-Turbo smart waste gate 38mm new.
-40mm tial bov? I have pictures
-Edlebrock Victor x Intake mani
-precision 1000cc injectors.
-Aem fuel rail.
-Hondata 4bar map.
-Hondata v1 s300 chipped ecu,
-Hondata intake mani gasket.
-Skunk2 throttle body 70mm
-Mishimoto radiator twin core slim with mishimoto fan.
-Mishimoto t-stat
-Mishimoto intercooler.
-Neukin steel IC pipes.
-Fuel lab pressure reg.
-Bosch 044 pump and walbro 255lph in tank.
-8an fuel lines with legit fittings to run with the car.
-Gates blue timing belt new.
-Msd 6an and blaster coil.
-Doc racing 1000$ lifetime Warranty top Mount manifold.
-Shitty 70mm eBay turbo
-Aem tru-boost controller
-Mechanical boost gauge.
Used Motec M400. Serial 13001-16211. Option unlocked are Single Lambda and 512k logging. Purchased ECU used but decided to go different route. Sent it in to Motec back in January for testing/unlocking and have not used it since. Will include a unused Bosch LSU 4.9 with purchase.
Ive got a few things for sale. See below. I can be reached by PM or text 580-382-1661. Text for faster response. Prices are firm unless noted. Prices do NOT include shipping unless noted. Buyer would pay shipping and PayPal fees. Serious Inquiries only.
First thing is a used Skunk2 Pro Series intake manifold for a GSR head. Used in good condition. - Sold
1 gallon jazz fuel cell, lid sticks and is hard to open sometimes. The lid flange could probably could be messed with to work better. Im selling because I got a different cell that worked for me better. Comes with mounting bracket. Has 2 feeds, -10an and -8an. And the return is a -6an. - $50
FCS 5 gallon fuel cell. Used, great condition. Comes with Cell and mounting brackets. - Sold
Magnafuel Pro Tuner 750 fuel pump. Rebuilt by magnafuel to new condition. The picture of the pump was when it was brand new. The blue has faded a bit due to the sun. - Sold
M&W Pro-10 ignition w/crane coil and T1 harness. Used for a few seasons. Im only selling because Im going to a coil on plug setup - $550
Ross racing pistons, B series 84mm. Low compression, used. 1 piston is brand new. Comes with Rings, which are brand new. Also comes with upgraded Ross pins which are also brand new. The new piston cost me about 150 and the pins cost me close to $100. Sold
Also trying to get rid of an obd2 GSR ecu. -$50
I have a set of skunk 2 pro 1 cams up for grabs, they have about 3500 street miles on them, never saw vtec. Still have the boxes and everything for them. Will NOT include the cam gears, only the cams themselves $475 shipped
Pic#1 Antique AEM V1 Engine Management. I have TWO of these. Was $400.00 in September, October savings now 300.00.
This is a good working unit, guaranteed. It also has some very interesting history that I will tell buyer.
Pic#2 Dented Anodized Black Overflow with filter, -12 fitting. $20.0
Pic#3 Black Satan powdercoated Overflow with filter and clamp , -12 fitting. $45.00
Pic#4-7 AFCO Radiator, custom. 16" wide, 17" Tall(18.5" tall to top of rad cap) 2.5" wide(6" wide with electric fan), -12 fitting on bottom, two `10 fittings on top, two 1/8NPT on side for sensors. Powder coated gloss black, fins have not been powdercoated. It's in great shape and will serve for many laps down the track. $300.00
Pic#8 Brand new BEGI FMU. $110.00
Pic#9 Vinyl wrap off of AEM PRORWD Honda, this is the real deal. It is 27" long, broke the picture down to two pics. Suitable for framing, you cut to suit your taste and frame it. $40.00. I have more. These actually came off of the original AEM car. Really cool to frame and hang. I have sold a few so far and only have a few lengths left. Once they're gone, they're gone for good. Again, these are off the original car.
Selling a pair of slightly used MT ET Streets Drag Radials, 235/60R15, on BN XXR501 15x8 +15 offset 4x100/4x114.3. Asking $400 Plus shipping. PM or Text @516Tree598378
CNC Worx/ Blackworks 5th Gear Handcuff for B series - $125 shipped
MSD cap for GSR - $40 shipped
Impact 5-pt Harness. Expired but in excellent condition - $80 shipped
Skunk2 70mm PRO Series Throttle body for B/D/F/H series motors (brand new) - $200 shipped
CCW LM20 wheels - 15x8 front 15x4 rear. Like new (no tires) - $1700 shipped
M&H 235/60-15 street & strip (100 miles) - $350 shipped
$300+ pp fees and shipping. this is rock bottom price, as good as your going to find.
AEM V1, its made for OBD2B, but we used a obd1 to 2b harness to run this in a EG.
I never pulled the clear film off the AEM logo, you get to do that!
I tried aem, didn't like it, selling it!
Buying a s300 for this setup.
Bought this used here on HT a few years ago, started a car with it, and its been in the closet since.
you can txt 423-957-1119, I take paypal, or credit card through Square.
im on ebay (darrinbrewer as well) im a power seller with 100% feedback! I sold ALOT on here back 8yrs a go(before the itrader rating deal started and vouch threads were removed), been out of the Honda stuff for a while.
I used to order a lot from Laskey, even flew to Cali and visited the shop, he's probably the biggest vouch I have on here.
thanks guys!
Came off my perfect running motor without any issues. Building a SFWD car so upgraded my valvetrain to Ferrea.
The GSR head it came off of was completely done by Portflow.
Comes with:
Dual Valvesprings
Titanium Retainers
Intake and exhaust valves
Keepers
Asking 450 OBO...will not part out unless I have a buyer for everything
Hello honda tech here to try and sell some stuff.
All prices are with out shipping or paypal fees.
I live in Blythe,CA so shipping to east coast can be spendy.
I use UPS also.
Shoot me offers and for questions.
contact me either here or via text message (760-984-4210)
GO-Autoworks A/C compatible 2.5 in down pipe with 3in exit has 2 o2 sensor bungs, Go-Autoworks cast manifold, and Turbonetics T3/T04 brand new turbo. i would like to sell these altogether. All these parts are brand new and have only been mocked up.-$750
Fuel injector clinic 775CC injectors with pigtails. Brand new never been used
-$250
AEM adjustable fuel pressure regulator for honda fuel rail. Brand new never been used.-$100
AEM Honda b-series high volume fuel rail-$100
Turbo XS dual stage boost controller brand new never been used.-$100
Older used Tial 38mm wastegate with 7psi spring in it.-$100
Older used HKS adjustable BOV-$75
Used Blox racing 0-100 psi liquid filled fuel pressure gauge-$25
*Please Read Whole AD*
1) I will not part out any of the packages do not PM me asking to sell you 1 rim/tire. If they are posted together in a package with a total price they will NOT be separated.
2) The prices are firm if you do not like them please do not PM me, if you offer less then my asking price I will not respond.
I have bought and sold lots on here so buy with confidence. I can provide numerous vouches if you require. All prices are shipped and in US dollars you must pay paypal or send as a gift. I am located in Canada but do not let this stop you from buying. Do not bother lowballing me I will completely ignore them. If you don't like the prices feel free to buy elsewhere.
Text or pm 306 551 5139
- K20/K24 Inline pro Fully built motor - Purchased from Jr Hurley himself. Built by inline pro. $5000 plus shipping WILL NOT TAKE IT APART 22006 Acura RSX Type S - K24 Drag Build
specs
InlinePro Race K24 block
K20 head
InlinePro billet crank
InlinePro main studs
InlinePro head studs
ACL Race bearings
CP Pistons
InlinePro connecting rods
InlinePro custom billet cams
InlinePro Stage 4 head package
InlinePro oversized stainless steel intake valves
InlinePro Inconel exhaust valves
InlinePro bronze valveguides
InlinePro machined rockers
InlinePro valvesprings
Supertech valves
InlinePro closed-deck sleeves
InlinePro cylinder O-rings
InlinePro notched block
- Turbosmart 60mm Wastegagte BNIB - $450 shipped
- G-force Long series K series complete Shifter(used but not alot)- $900 shipped
Selling my turn key 9.70@147.4 97 Civic for $12,500. Absolutely nothing is removed from the car. It comes as shown in the pictures ready to rock. Check out the Craigslist add if interested. Car makes 640whp@23.7 psi, 719whp at 29 psi, and 758whp@34psi on our dynocom dc5000fx dyno. I ran the 9.70 pass with 15 psi in first, 20 in 2nd, 29 in 3rd, and 29 in 4th. Car weighs 2,520 with me in it.
BWR Topmount T4 twin WG brand new 750
Borgwarner S366 brand new 650 obo
Borgwarner S366 dyno session and 4 passes 500
B series AEBS sleeved block might need hone
B16 Head with Supertech Valvetrain 650 obo
Type R cams 350 obo
B16/ITR itbs custom made 250
B series 1st Gen Full Race Ramhorn before bots started making them 450 obo
Cometic B series headgasket 90
Inline pro log manifold Kit with s366 barley used turbo, 44mm Tial WG, and pipings for it 1300
Magnus GSR Intake Manifold 700 obo
All Star & Greddy Catch can both used 50 each
Bseries stock Axles one was bought New 120
Racing Gear JTC N1 Acura/Honda suspension pillow ball top mounts 600 brand new like 2000
B18 19teeth water pump 40 obo
Bseries Oil pump used 60
Mishimoto used full-size radiator 140
Mishimoto brand new full size Radiator 220
Fluidyne used half core radiator 150
2 civic stock seats make offer
Prices are OBO
PM me for anything you may need or pics of.
