help needed
Old Nov 5, 2002 | 04:32 PM
oldirt3277's Avatar
New User
Default help needed
Hey if you are willing to help please email me with your thoughts. I have posted numerous times about an irratic idle and all I have gotten was smart *** remarks I thought we were all here to help each other.Well here's the prob- I have a 94 ex coupe d16z6 with cold air ,a hollowed out cat,basically a straight exhaust witha tsudo pipe,chikara header and all of a sudden after my car half *** warms up it surges at idle from 1000-3000 every so often but happens less when the lights are on then my thought when the coolant fan comes on it idles steady around 1200 so what could be the problem the dealer tried to tell me that it was the IAC valve I replaced that along with the map sensor off another d16 I am building but the problem persist.The only thing is when I disconnect the throttle position sensor when running it takes the idle to 3500 and stays there so could my prob be the tps? hit me back if ya can help any thoughts appreciated. Thanks mike ps also checked for vacum leaks and none present as everyone does not beleive or they beleive it is the answer
Old Nov 5, 2002 | 06:00 PM
Chiovnidca's Avatar
Default Re: help needed (oldirt3277)
Hey if you are willing to help please email me with your thoughts. I have posted numerous times about an irratic idle and all I have gotten was smart *** remarks I thought we were all here to help each other.Well here's the prob- I have a <U>94 ex coupe d16z6</U> with cold air ,a hollowed out cat,basically a straight exhaust witha tsudo pipe,chikara header and all of a sudden after my car half *** warms up it surges at idle from 1000-3000 every so often but happens less when the lights are on then my thought when the coolant fan comes on it idles steady around 1200 so what could be the problem the dealer tried to tell me that it was the IAC valve I replaced that along with the map sensor off another d16 I am building but the problem persist.The only thing is when I disconnect the throttle position sensor when running it takes the idle to 3500 and stays there so could my prob be the tps? hit me back if ya can help any thoughts appreciated. Thanks mike ps also checked for vacum leaks and none present as everyone does not beleive or they beleive it is the answer
Is this an Accord with a Civic engine?
Old Nov 6, 2002 | 08:16 AM
urbanlegend21's Avatar
New User
Default Re: help needed (Chiovnidca)
we are having a similiar problem with a Prelude so if someone would answer this please
Old Nov 6, 2002 | 12:09 PM
boonacka's Avatar
Default Re: help needed (urbanlegend21)
check the Fast Idle Valve.. ive heard of some peeps blocking off the FIV with a plate and said they fixed the problem. i have yet to try it cuz of lack of time. my car still idles pretty rough around 550 rpm sometimes it drops below 500. i'm gonna try replacing the Idle air control solenoid as well. let me know if anything works..
oldirt3277
Acura TL, RL & ZDX
Nov 6, 2002 05:56 PM
oldirt3277
Nov 6, 2002 12:02 PM
oldirt3277
Nov 6, 2002 01:36 AM
oldirt3277
Nov 6, 2002 12:39 AM
oldirt3277
Nov 5, 2002 06:30 PM
