17da1 broken timing belt
Old Sep 30, 2015 | 04:18 PM
jahenderson1's Avatar
Default 17da1 broken timing belt
Need some help...
Broken timing belt on a 2002 Civic LX...17da1..
During reassembly, is it possible to have the cam 180 degrees out, or do the sensors compensate for that. Everything will be placed on TDC, but can the cam be out, or am I way off in my thoughts, here....
Or is the cam gear 2X size of the crank gear?
Old Sep 30, 2015 | 07:19 PM
king06's Avatar
Default Re: 17da1 broken timing belt
Your out of your thoughts. Cam gear has to be perfectly aligned or will run like crap or worse will make your valves meet a piston, and they don't like each other.
Remember its only piston number 1 that has to be At tdc.
Old Oct 2, 2015 | 06:23 AM
Thanks....took at closer look at the timing....2 revs for crank = 1 rev for cam...got it....
scoob8000
Dec 19, 2011 11:57 AM
DumpdEJ6
Sep 12, 2010 08:05 AM
EFjalopy
Jan 8, 2010 02:54 PM
EK4 hatchback
May 31, 2004 08:45 PM
rasta420
Oct 1, 2003 07:53 PM
