"Race Gas" fuel additive
Old Sep 28, 2015 | 04:53 PM
darnizzle8805's Avatar
Default "Race Gas" fuel additive
I'm not saying that im planning on using it, but curious if anyone has used it, and if it works as well as the company says.
I have a 13.25:1. 85mm B20/P8R, Crower 62405a build, and could use some ideas on which fuel i should run, i was planning on 93, or a 93/race fuel mixture. A bit high for straight 93, but my cams have a lot of overlap, so they will bleed off a lot of compression. The area I drive/race is sea level to at most 500ft above.
Old Sep 28, 2015 | 09:29 PM
Pullig's Avatar
Default Re: "Race Gas" fuel additive
Ive tried it on my boosted setup it does work... but I didn't like how it coated my sparkplug porcelain and ground strap orange making it almost impossible to even read them
Old Sep 29, 2015 | 11:48 AM
Dark_Teg's Avatar
^^^This........I use it in my Lightning but it does turn the plugs orange.
Old Dec 31, 2015 | 12:11 AM
martin88's Avatar
Any feed back on this? What brand are you using?
Old Jan 2, 2016 | 04:34 AM
D-Rob's Avatar
Do you have access to ethanol fuels?
Old Jan 4, 2016 | 04:04 PM
If directed to me, no i don't.
Old Jan 4, 2016 | 09:43 PM
96ekb20's Avatar
best thing to do is do a dynamic compression cal on the motor first
Old Jan 5, 2016 | 02:45 AM
martin88's Avatar
So whats next move after the dynamic compression calculator?
Old Jan 15, 2016 | 08:11 PM
F22Master's Avatar
Just go to your local small airport and pickup some 100 Low Lead AvGas.
Just take your O2 sensor out before you run the stuff.
wantboost
Apr 27, 2013 11:34 PM
adrian98
13
Oct 20, 2009 01:18 PM
TCr-Vtec
Mar 8, 2007 02:46 PM
toooslow
Nov 12, 2003 11:08 PM
DsITR
Nov 20, 2002 10:12 AM
