Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Steering Rack knock
Old Sep 28, 2015 | 09:20 AM
rovafa2002's Avatar
Default Steering Rack knock
Hi I have been trying to diagnose a rattle comming from the passenger side front wheel of my 2006-2007 Civic EX Sedan for a while. It happens while going over bumps, and I mean bumps where the street is kind of cracked. The noise is not reproducible while going on an uneven surface, only when the wheel hits a crack.
So far what I have done is:
- Retightened the 6 power steering rack bolts to the specified torque
- Changed the passenger side inner rod
- Changed the passenger side Sway bar link
- Adjusted the Steering Rack Guide
After doing all of these things got better but If I move the wheel left to right lots of times with the car on jackstands I can feel a knock and some play on it. It is really looking like its coming from inside the rack so I don’t know what I should replace in there.
The car has almost 60k miles, my previous 99 EX had over 130k miles and after doing the steering rack adjustment a very similar noise (if not the same) went away.
Any ideas on how should I fix this noise?
Old Sep 29, 2015 | 02:24 PM
JoeBlue's Avatar
Default Re: Steering Rack knock
Have a video for what it's doing when you turn it?
Old Oct 1, 2015 | 09:07 PM
ekb16's Avatar
check your lower ball joints
Old Nov 4, 2015 | 05:34 AM
rovafa2002's Avatar
Ok at this point i am 100% sure the noise is coming from the rack only from the right (passenger) side.
I live in Uruguay and here you dont get Rebuilt Racks that easy as in the US, you have to take them for repair. Since I dont have any leak. I am thinking of fixing it myself, however I dont know how complicated it would be.
I am thinking on taking the 6 bolts out so I have some space to work on but without taking the rack out. I was thinking on taking the inner and outer rod and replacing part 53630-SNA-A01, its the #11 in the below diagram
2006 Honda Civic 4 Door EX KA 5MT P.S. Gear Box Components (HPS)
I have some doubts regarding the "Seals" on #1, are these seals to avoid PS fluid to come out? or just to keep the rack clean? I dont know much about racks but I suppose the fluid just goes through the pinion assembly only.
theYBLEGAL
Aug 2, 2017 08:23 AM
rovafa2002
Jan 10, 2016 10:54 AM
rovafa2002
Sep 28, 2015 09:24 AM
theemaddhatterr
Dec 7, 2006 03:44 PM
