Tips for Refreshing EH9 suspension for DD'ing
Old Sep 27, 2015 | 02:12 PM
goo_punch's Avatar
Icon5 Tips for Refreshing EH9 suspension for DD'ing
Good afternoon, I have a 1995 Civic EX sedan that I use as a daily driver (150 mile commute every day). I take a lot of winding roads as well as some highway. I've been looking for tips on restoring and improving steering and suspension.
So far I've replaced:
-Front LCAs (Dorman)
-Front UCAs (TruHart adjustables)
-Rear LCAs (OE w/ new bushings)
-Rear UCAs (TruHart adjustables)
-Outter Tie Rod Ends (unknown brand)
-Strut/Coil/Mount Assemblies @ all 4 corners (FCS from rockauto)
-Front and Rear Stabilizer Bar Endlinks (unknown brand)
-Rear Trailing Arm Bushings (Duralast)
-Rear Toe Arms (unknown brand)
-BWR 3 pt. front upper strut tower brace
-15" LS Mesh w/ 195/50/15 Kumho Ecsta ASTs
Was hoping someone could suggest what I should replace/add next. Do the rear upper strut tower braces really make much of a difference? I was told the rear lower braces make a decent impact. ANY help would be much appreciated!
Thank you!
Old Sep 27, 2015 | 02:25 PM
NotARaCist's Avatar
I never narc'd on nobody!
Default Re: Tips for Refreshing EH9 suspension for DD'ing
Considering that you use the car as a DD, and not a track ****, you've already gone overboard on what would be useful to you. No, a rear upper strut tower brace isn't going to make a noticeable difference for you. No, a rear lower brace is not going to make a noticeable difference for you. This stands doubly true if you plan on getting more BWR ****.
Old Sep 27, 2015 | 05:27 PM
redm3turbo's Avatar
yea, seriously. I redid a eg civic suspension...everything top to bottom all stock.. Got in, took it for a ride, no noticeable difference. Just change things that are broke, leaking, etc
Old Sep 27, 2015 | 06:25 PM
Bently_Coop's Avatar
Steve at Heart
Read over thread linked below for a good start.
https://honda-tech.com/honda-civic-d...build-3179269/
Old Sep 28, 2015 | 10:57 AM
tony_2018's Avatar
Fish Twig
Taking winding roads with stock suspension isn't going to work. You can look into an integra setup because those cars were built with a somewhat sport suspension, basic integra LS struts and springs, LS front and rear swaybar is a decent upgrade.
crazyguy
Jun 14, 2007 06:01 AM
93formula
Sep 7, 2005 07:49 PM
paulzy
Feb 2, 2003 06:49 PM
MechEng
Feb 15, 2002 05:47 PM
