93 honda civic hatchback wont start
working on my sons Honda civic hatchback. It wont start. It has spark at the plugs. The fuel pump won't prime and has no power at the harness connecting to the pump. Took the pump out and put 12 volts directly to the pump and it works. Checked the relay based on information I found on the internet and it seems to have continuity where it should when 12 volts are applied to the different posts of the relay. What next?
Key off.
Unplug ECU connector A.
Ground pin A7 or A8 in the connector.
Turn key to ON(II) and listen for whether the pump primes.
Repeat ground test multiple times to check whether the pump primes with A/7/A8 grounded.
There are 3 plugs to the ecu. which one is connector A and which connectors are A7 and A8? when you say repeat test a number of times do you mean turn the key on and off repeatedly to see if the fuel pump begins to prime?
http://www.phearable.net/images/tech...schematics.gif
Yes
Unplug main relay.
Turn key to ON(II).
Two of the eight pins in the connector should read battery voltage to body ground.
Post the voltage readings and the two pins and wire colors that show battery voltage.
Turn key to ON(II).
