Suspension & Brakes Theory, alignment, spring rates....
Blox rear sway bar links, EG & integra
Old Sep 23, 2015 | 05:47 PM
gmcuajo1's Avatar
Default Blox rear sway bar links, EG & integra
I have an EG 93 del Sol which I will be in stalling a 14mm rear sway bar out from an integra. The end links that connects with the LCA have worn bushings.
Energy Suspension nor Prothane make those bushings. Or at least don't find them. If anyone know good bushings please recommend. If red, better.
I found on eBay Blox end links that looks different than OEM. Anyone with experience with those Blox end links?
Old Sep 23, 2015 | 06:00 PM
gmcuajo1's Avatar
Default Re: Blox rear sway bar links, EG & integra
Pictures of both.
Old Sep 23, 2015 | 09:07 PM
redlinetuning's Avatar
Just get oem integra endlinks. Those blox ones won't fit unless you have adapter bushings.
Old Sep 24, 2015 | 04:02 PM
98civdx's Avatar
Master Detailer
^that.
They wont fit and wont last. And once you press the adapters in the sway bar, good luck getting them out.
Old Sep 24, 2015 | 08:11 PM
spAdam's Avatar
Loved
Community Favorite
The ones in the first picture are for a 96-00. The ones you need are the second pic. Go oem if you can, whatever you do stay far away from the blox "spherical" ones.
Old Sep 24, 2015 | 08:50 PM
Bently_Coop's Avatar
Steve at Heart
Friend had the Blox spherical's and they blew out quick. OEM or maybe Hardrace
Old Sep 24, 2015 | 09:02 PM
spAdam's Avatar
Loved
Community Favorite
Yeah, they're made from $2 Chinese rod ends. You have to spend good money if your going to use those... Aurora or bust IMO.
Old Sep 25, 2015 | 04:04 PM
gmcuajo1's Avatar
Box says "92-00 civic, del sol, 94-01 integra". Should fit or are different?
Will check if mu bar have the OEM and just change the bushings.
Old Sep 25, 2015 | 04:08 PM
spAdam's Avatar
Loved
Community Favorite
Box is wrong. You might be able to make them fit but no, they are not correct.
Old Sep 27, 2015 | 04:02 PM
98civdx's Avatar
Master Detailer
this like 20 times over again. I regret nothing more than buying those pieces of ****
JAVID_ej1
Suspension & Brakes
16
Jun 14, 2010 08:24 AM
bleedblue94
Suspension & Brakes
14
Mar 29, 2009 07:57 PM
Paul-eg
Aug 29, 2008 04:33 PM
memphiss13
May 30, 2002 06:38 PM
