i'm in limp mode
Old Nov 5, 2002 | 03:07 PM
respectblades's Avatar
Default i'm in limp mode
i'm in limp mode....
i have a 94 hb with a jdm b16 (2nd gen)
i'm getting codes 7 and 14
which are the tps and idle air control valve
how do i get out of limp mode?
any suggestions on how to fix this
do i need a new trottle body?
i changed the tps because it was broken does this change the factory settings that come with it? and would this cause i the IACV to get me a code too?
Old Nov 5, 2002 | 03:40 PM
Rocketman's Avatar
Default Re: i'm in limp mode (respectblades)
VIAGRA and lots of it.
Old Nov 5, 2002 | 03:54 PM
KoRE's Avatar
did you reset the ECU?
Old Nov 5, 2002 | 03:55 PM
black2kcivic's Avatar
Default Re: i'm in limp mode (KoRE)
im in limp mode as well... I blame my unattractive girlfriend
Old Nov 5, 2002 | 03:59 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: i'm in limp mode (black2kcivic)
anytime you change bad sensors ALWAYS reset the ECU so it can erase it, otherwise it will think it's still bad, it's kinda dumb in that way. Pull off your IACV and clean out the screen and spray some carb cleaner inside and so if that fixes it. When these go out, it's mostly due to deposits on the screen which restrict air flow to the intake manifold.
Old Nov 5, 2002 | 04:02 PM
KoRE's Avatar
Default Re: i'm in limp mode (Emerica)
Well put
Old Nov 5, 2002 | 04:39 PM
SRT-WHORE's Avatar
Old Nov 5, 2002 | 05:33 PM
GapxGuy's Avatar
Sushi Buffet Champion
HAHA
Old Nov 5, 2002 | 05:37 PM
97hb's Avatar
Default Re: i'm in limp mode (SILINITY16)
Old Nov 5, 2002 | 05:42 PM
scotty9669's Avatar
unattractive girlfriend? how did u get into that one? she blackmail u? or does she have money
Old Nov 5, 2002 | 05:44 PM
DV98CVC's Avatar
Default Re: i'm in limp mode (GapxGuy)
HAHA
haha haha haha
Old Nov 6, 2002 | 12:03 PM
Default Re: i'm in limp mode (DV98CVC)
i reset the ecu and i did spray carb cleaner in it
if i change my trottle body will that fix it
Old Nov 6, 2002 | 12:06 PM
Evs-One's Avatar
Solbros Owns Me
and that didn't help? No, changing your throttle body won't do anything because the IACV lets air bypass the TB and go right into the manifold. If that didn't work then you're gonna have to get a new/used one.
Old Nov 6, 2002 | 12:59 PM
i'm assuming you mean a new or used IACV
i'm guess i'm luvky my friend has one in his garage and its jdm
jltucker31
Mar 10, 2009 03:06 AM
ko
May 22, 2005 10:54 PM
89 pos
Oct 7, 2004 11:47 AM
RRRex
May 24, 2003 01:52 PM
